Could a missing (or broken) thermostat cause this?
Hello (yet again)! I have yet another issue with my lovable Aerostar. This one I just noticed today. The heat doesnt work! Not that its very needed here in Florida, but its still an issue. I tried the heat function out multiple times today and even after driving for a good 20 minutes hot air does NOT come out! Only cool air comes out the vents. Well actually, for a few seconds when I turned the heat on it sort of felt "slightly warmish" but a few seconds later it was cool again. I don't know if this could be related but the temperature gauge is stuck at C (Cold) as its been since I purchased the van about a week ago. I brought the van to my friend who's a mechanic and he looked under the hood and claims there is no thermostat, the previous owner must have removed it. I found this odd since the vehicle has yet to overheat and I know overheating is sure to happen when the thermostat is missing. Can anyone confirm if these signs are indeed because of either a broken or missing thermostat? If it is, I have yet another problem. I began looking on eBay for a new thermostat and there's all different kinds! Some say "190 degree" some say "180 degree" and some say other things. Here's a link to a "190 degree":
MOTORCRAFT RT-1152 Thermostat | eBay
If I do need a new thermostat, what kind do I need? Here's the exact van I have: 1989 Ford Aerostar XLT V6 with 4 speed auto transmission. Oh and just in case this has anything to do with it, the van has A/C but it's not currently working.
Thanks!
Thanks!
Thermostats regulate engine temperature by restricting the coolant flow through the radiator. It can't prevent overheating if the engine is having a heating problem. A thermostat stuck open (or missing) will make the engine run too rich as the computer keeps it in the warm-up mode.
If you think you need a new thermostat, you should be able to find the correct model at your local auto parts store. They all have cross-reference guides to help you choose. Also, get one that opens at 192F, as that's what your engine computer needs to work with.
I don't think the thermostat is making your AC inoperative.
A few additional words of wisdom. There is a right and wrong way to install the thermostat. Since you do not have one installed, you should refer to a manual for the correct way to install. (Bleed hole position and which side of thermo goes where)Autozone has a free online repair guide you can consult to help you along.
Also, the nuts/studs tend to get corroded and rusty. More than one person has posted the woes of snapping off their thermostat stud while attempting to get the nut loose. Soak the nuts/studs with a penetrating oil (PB Blaster, etc) for several days before attempting to loosen the nuts.
Last edited by aerocolorado; 04-26-2012 at 02:27 PM. Reason: spelling-someone keeps stealing my vowels.
The water pump was replaced by previous owner due to overheating. Its still shiny and all, can tell it was really replaced. But after looking up the purpose of a thermostat a little bit further, I'm now wondering why the original one was removed in the first place. If the water pump solved the overheating problem, why is the thermostat still missing? I hope it doesn't start overheating if I install a new thermostat.
mark_H1254
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
07-10-2002 08:26 PM
mark_H1254
07-09-2002 06:28 PM
