2005 F250 SD 6.0 Diesel - Ford Truck Enthusiasts Forums
Old 04-24-2012, 09:41 PM
DGMFORD's Avatar
DGMFORD DGMFORD is offline
DGMFORD is gaining momentum as a positive member of FTE.DGMFORD is gaining momentum as a positive member of FTE.
My 250 is giving me crap again. I seem to go through this ever 8 to 12 months. It's warm here now in Texas and I don't expect to have this issue until winter.
When I start the truck for the first time, (sitting over night) the truck will turn over, hit for a split second, and then it dies. The only way I can get it to start is if I hold the gas pedal down. Then once it starts, it runs like crap until it warms up about 10 to 15 minutes before it start to run good.
At times it will blow out white smoke for a couple minutes as well.
The kicker here is if I plug it in overnight, it will start right up and run like a top. The last time I had it into ford, they said my batteries were bad and they flashed the injector module, the truck ran good for a few months and now we are back to square one.
The one thing I had thought of was the starter. If the starter is not spinning the engine fast enough would that cause this issue? I donít think the starter has ever been changed, which may have been the reason after changing the batteries that it helped for a while. The other thing I thought of was oil, I currently use Fords 15W40. I read a post where they were using the 10W30 Diesel oil. I would only think that would make a difference in colder weather.
Thanks <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old 04-24-2012, 09:43 PM
MisterCMK's Avatar
MisterCMK MisterCMK is online now
Avid Winter Hater
MisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputation
What is the FICM voltage?
Old 04-24-2012, 11:16 PM
DGMFORD's Avatar
Good question, not sure what that is or how to test it, is that the Fuel Injection Control Module?
Old 04-24-2012, 11:24 PM
texastech_diesel's Avatar
texastech_diesel texastech_diesel is offline
Disgruntled Texan
texastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputation
Yes it is; the FICM basically turns 12V to 48V and fires the injectors, sagging voltage (from blown components sometimes caused by an aggressive inductive heating strategy) burns out the board, and the truck runs like crap.
FICM test procedure:
http://www.ford-trucks.com/forums/89...procedure.html
You can also buy an OBDII monitor like a ScanGauge (http://www.amazon.com/dp/B000AAMY86/...hvptwo=&hvqmt=), Edge Insight CS or CTS, DashDaq, AutoEngenuity to read the FICM Voltage without having to crawl under the hood.
Less than 45V at any point from cranking to running, call ed at FICMrepair.com and see if he can fix your unit, and maybe change the flash out on it to one of the better inductive heating strategies (or none at all).
Just an FYI, holding the pedal down doesn't do anything, the PCM will ignore the input and follow it's programming. This is probably a FICM issue because it runs rough until it warms up and plugging it in seems to help, but if it's been on-going for awhile you could have killed an injector along the way. Does the white smoke smell like diesel? And are you growing any oil in the crankcase? Because fuel dilution can cause serious engine problems, so make sure your oil level is correct.
The starter probably isn't a problem, because the way the glowplugs pull current the truck runs on batteries for up to 120 seconds every start cycle. During that time the batteries are getting hammered, and the FICM might be sagging trying to pull enough amps out of them to fire the injectors. They aren't deep cycle batteries, so drawn out high current draw will kill them faster than normal car batteries, and the FICM will suffer for it.
Also, 5W40 diesel-rated oil is preferred, it'll help cut down on the rough starts because the oil side of the injectors will flow better when you start it. Most guys won't run 10W30, since the 6.0L injectors shear the oil you'll have to go to a more frequent oil change interval to keep the viscosity from falling too far down.
I'd recommend that you check the FICM voltage, switch to 5W40, and change your fuel filters if they haven't been changed in the last 10k. Buy the ScanGauge and start reading the 6.0L tech folder and you'll get it squared away.
Old 04-24-2012, 11:26 PM
DGMFORD's Avatar
I found this post, will do some further research and test the FICM. Thanks for the tip. Any other ideas, please let me know. thanks again.
Old 04-25-2012, 05:14 AM
Tylus's Avatar
Tylus Tylus is offline
Nuclear Machinist Mate
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
Quote:
Originally Posted by Johnclave777 View Post
You are really facing a critical issue with your F250 most of the same model face such problems.................
what does that mean?
Old 04-25-2012, 10:21 AM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Quote:
That was a spammer from India. He's gone bye-bye now.
Carry on.
To the OP, I've moved your thread to the 6.0L Powerstroke Diesel forum for better assistance.
Old 04-25-2012, 11:09 AM
DGMFORD's Avatar
Thanks for the info, I will start looking into this problem this weekend. Also I plan on changing to the 5W40 and see if that helps as well.
thanks again.
Old 05-03-2012, 08:49 PM
DGMFORD's Avatar
I tested the FICM at Key On and have 48.4 volts, I was unable to test while starting as I was by my self. I will test as soon as I can find a helper. She wont start at all now, just hits once or twice and dies. Could this be the High Presure Oil pump? or possibly pluged fuel filters?
Old 05-11-2012, 05:21 PM
DGMFORD's Avatar
Guys, still working on the Diesel, are there any scan tools that will check the High Presure Oil pump output? And has anyone used the Auto Enginuity PC scan tool?
Thanks
Old 05-11-2012, 06:48 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
AE scan tool seems to be the favorite here. clay at riffraff a PM or call him hes the sight sponser that I know sales it.
Old 05-11-2012, 07:28 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32 weekendwarriorfsw32 is offline
Master of Strokes
weekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud of
Here is what you will need, and you will find out that it is very useful. I got mine from Riffraff as well, best price I could find and got it in 2 days with free shipping. Looks like they are still offering the free shipping as well.
Riffraff Diesel: AutoEnginuity Total Ford Enhanced Bundle
Old 05-12-2012, 12:32 AM
DGMFORD's Avatar
Thanks, I sent him a message.
Old 05-12-2012, 03:48 AM
Yahiko's Avatar
Yahiko Yahiko is online now
Yahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputation
Hi,
DGMFORD
It might be a good time to check the batteries . Bad batteries in the cold
only do worse. Also check the cables for any corrosion.
On a cold day in March I got dumped in a parking lot on the overnight test drive.
Sales man said sorry. I said "No problem BUT you will replace the bad cables"
They did..
So while you have some time and if you have a ride that you can use take the batteries
in to a shop and have them tested.
Good luck
Sean
Old 05-12-2012, 04:05 AM
bismic's Avatar
bismic bismic is online now
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
There is a no-start checklist in the Tech Folder.
Something to consider related to our chapter. DRRXR Texas Chapter 53 11-20-2011 05:00 PM
Anyone have an idea on what my 460 is up to? 38-72 1987 - 1996 F150 & Larger F-Series Trucks 3 05-25-2011 11:07 AM
CLUNK! coming from front end while in 4x4 mgidaho 1999 to 2016 Super Duty 2 12-07-2010 10:43 PM
2008 F150 Side Mirrors B00st 2004 - 2008 F150 1 01-07-2010 11:47 AM
351W Issues when warm Rookie Shade Tree Mechanic CALINLEIR Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 3 04-28-2009 02:47 PM
Tags
2005, 60, 61, diesel, disel, f250, ford, forum, list, motor, oklahoma, problems, shops, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
