87' 460 Motorhome - Ford Truck Enthusiasts Forums
87' 460 Motorhome
Old 04-24-2012, 07:47 PM
m350 m350 is offline
m350 is gaining momentum as a positive member of FTE.
87' 460 Motorhome
Hey Guys,,,Looked at a 87' Ford Motorhome today,,,found out it was a 460(owner was'nt sure),,,39k miles on it,,,seem to run ok,,maybe a slight skip exhaust (fuff fuff),,,Just wondering what kind of HP and Torq these things had ??
Looks all stock,,vacum hose's all over the place, airpump, EGR, etc.,,,,,Mark
Old 04-24-2012, 08:20 PM
raytasch's Avatar
raytasch raytasch is online now
Old guy with old toys
raytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant future
Can't tell you what exact figures RE torque and HP but the torque will most likely peak at about 2200. 1987? probably carbed? Manifolds can be a problem with these applications. Headers help the problem. Emissions could be a problem if check required. What transmission? Early E4OD problematic. But you knew that. Service records?
I would be more concern about the size, weight, brand and condition of the motorhome itself than the 460. Look for water intrusion everywhere. If you find soft wood, run unless you're looking for a real project and can buy it right. Good luck.
BTW, don't expect over about 6-7 mpg.
And tires should be replaced after 5-6 years.
Old 04-25-2012, 03:51 AM
Yes it does have a carb,,,Pretty sure it's a C-6 tranny, No O-drive on shifter and the tranny Pan has the Notch/L-shaped,,,,, C-6 style I beleive ??
Yes could see some sagging/Bow in upper bunk area,,,lady said she had a Rubber roof Installed,,,
If I could find one this around this year in Good enough condition,,,usually pretty cheap,,,Just time and weather are the enemy!
Old 04-25-2012, 03:04 PM
ArdWrknTrk ArdWrknTrk is offline
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
If it's the same engine as in my '87 P/U it's rated at about 220Hp.
With only 39k on the clock I would suggest you swap the timing chain and plastic gears for a set that is not retarded.
For about $50 + gaskets it will make a big difference in how the 460 is able to drag that weight around.
Old 04-25-2012, 04:29 PM
mustangman mustangman is offline
mustangman is starting off with a positive reputation.
check every exhaust manifold bolt 16 bolts, you might have to take the heads off to fix,once you get some good headers like BANKS on the 460 youll feel alot better no more worrys,i prefer the c6, the e4od will save gas but very costly when it breaks down
Old 04-26-2012, 06:15 PM
Wont be buying the 87',,trying to find something in better condition,,a few to many Dent/Dings!
So whats the Deal with the stock, retarded timing chain/gear setup on a 460 ??
Also do the stock exhaust manifold bolts Break easy/alot ?
Old 04-26-2012, 06:36 PM
pedant
All 385 series engines from 1971 (i believe) until they were fuel injected ('88 for pickups, '90 for motor homes and other chassis)
were 4 degrees retarded for emissions reasons.
By using pre 1970, post '88 or aftermarket performance timing set you will gain quite a bit of torque.
In a motor home droning along the highway for hours tends to warp or crack cast iron manifolds.
The studs get extremely hot and then the nuts come loose.
Exhaust leaks abound just because of the kind of service these vehicles see.
Old 04-30-2012, 06:53 PM
Great Info on the 385 series,,,thanks ArdWrknTrk !!
87 Ford E350 Signal light whaase 1968-2013 Full Size Vans 1 06-16-2015 09:32 PM
No Power to Fuel Pump on E350 Cutaway with 460 synergy141 1987 - 1996 F150 & Larger F-Series Trucks 22 08-24-2013 06:41 PM
Motorhome 460 McCormick 1987 - 1996 F150 & Larger F-Series Trucks 19 07-10-2011 07:10 AM
location of the fuel pump on a carb'd 87 460 synergy141 1987 - 1996 F150 & Larger F-Series Trucks 20 11-18-2010 12:09 PM
87 351W in a Motorhome rfriedman20 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 13 05-30-2003 11:36 AM
Tags
460, bolt, break, engine, exhaust, ford, home, manifold, marks, maximum, motor, motorhome, rpm, rv, timing, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
