ignition coil b on 1996 ranger 2.3l - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 04-24-2012, 07:37 PM
96rangerkid 96rangerkid is offline
96rangerkid is starting off with a positive reputation.
Hey i was wondering if anybody could anwser this question: my engine has 2 ignition coils, and b went bad, but i have no idea which one is b. Help?
Old 04-25-2012, 08:56 PM
LastStarfighter's Avatar
LastStarfighter LastStarfighter is offline
LastStarfighter is starting off with a positive reputation.
I would guess that Ignition b would be the one with the wires running to the intake side of the engine.
just a guess.
Old 04-25-2012, 09:13 PM
i hope your right. i just had one replaced and got worried it was defective. thank you.
Old 04-26-2012, 05:50 AM
powersmoked's Avatar
powersmoked powersmoked is offline
powersmoked is gaining momentum as a positive member of FTE.
Quote:
just a guess.
my guess for B is also the driver-side(intake)
that is the side that ignites on the exhaust stroke......on cold starts it will not even fire...........if that was the one that got replaced the truck should have still started and ran.....
Old 05-03-2012, 07:48 PM
it wasnt, but then i switched and cleared the code it came back. i found that the ground was also slightly oxidized. i cleaned it and im waitin to see what it does. thank you tho
Old 05-03-2012, 08:13 PM
If that fixes it throw some dialectic grease on there. It will keep it nice.
Old 05-07-2012, 07:21 AM
i have done that and my code came back. im starting to think its resistor that is right before my ground. i'm gonna try doing a voltage drop test and see what happens
Old 06-22-2012, 03:00 PM
samw57 samw57 is offline
samw57 is starting off with a positive reputation.
my truck spudders on acceleration in 3rd & 4th gear. I've replaced all the plugs and wires but not the coil packs. Starts up just fine and doesn't act up while idling. I was going to check the ground and connections to make sure they are corroded. any other suggestions would be great help
Old 06-23-2012, 12:09 AM
michigan66's Avatar
michigan66 michigan66 is offline
michigan66 is gaining momentum as a positive member of FTE.
Take the old coil pack to an auto parts store and have them bench test it before you spend more money on parts. Also, you indicated that you have a trouble code. Post it here and we can be of more help to you.
Old 06-23-2012, 12:56 AM
KhanTyranitar's Avatar
KhanTyranitar KhanTyranitar is offline
KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.
Fires on the exhaust stroke. Um that doesn't even make sense. Both coils packs are waste spark, so they BOTH fire on both the intake and exhaust stroke.
It is true though that only one coil pack fires during startup.
ignition coil connectors? westend 1999 to 2016 Super Duty 2 02-13-2017 10:45 PM
IGNITION COILS mcmain Aftermarket Products 1 11-07-2016 03:33 PM
ignition help naccordino Ford Inline Six, 200, 250, 4.9L / 300 4 05-17-2015 09:14 AM
Dtc 0350 - 0362 skoveng Modular V10 (6.8l) 10 10-29-2008 07:07 PM
69 ford 351w ignition wiring 1 wire alternator marklut1 Electrical Systems/Wiring 6 07-10-2004 08:10 PM
Tags
1996, 23, 23l, 96, coil, diagram, engine, ford, ignition, ingection, marks, on1996, ranger, test, timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
