You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Hi, I'm knew as you all know. I have a 1960 f100 with a 292. i have a oil leak at the oil filter. It still has the cannister type. I am looking for the paper gasket that mates the block and the plate together and I also need the rubber gasket that seals the cannister to the plate. Any help is appreciated
Thanks Mike
I am looking for the paper gasket that mates the block and the plate together No such gasket shown or listed in Ford parts catalogs.
I also need the rubber gasket that seals the cannister to the plate. EAA-6838-A / Also furnished w/the cartridge oil filter.
Welcome to FTE
Why mess (in more ways than one) with the old by-pass cannister oil filter when you can install a gen-u-ine Ford full flow Spin-On oil filter using its adapter kit instead?
While this kit was introduced in 1957, it was an option on some 1957/64's. I just looked this same puppy up for a member of the 1961/66 forum.
B7A-6882-A .. Spin-On Oil Filter Adapter Kit - Use with Motorcraft FL-1A Oil Filter (most common oil filter used 1957/96) / Obsolete / 1,537 (!!) available NOS.
Thank you for the response, I was told that there is a impregnated paper ring or gasket that goes between the block and the oil filter plate. I will go with the adapter kit.thank you very much
