You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Took the truck in to the local dealer today to make sure I had the latest flash, change the oil and all filters. My coolant was low and so they did a pressure check as well. The outcome, I already had the latest flash, no leaks in coolant system, they topped off my coolant. Oil and all filters replaced and they pulled my door unlock code to boot. They got me for $126 and there was a NC for pulling the door code. I furnished the oil, and all filters. Diesel Mechanic said the ol rig is in great shape. He also recommended using a fuel additive called Diesel Dry. He said you keep the water out of the fuel, do the recommended services throughout the life of the truck and I won't have any problems. I chuckled and said, time will tell.
I provided both fuel filters and the oil filter and the oil. They charged me $17 for the oil change, and something like $80 to change both fuel filters. I though $80 to change the fuel filters was a bit high, but this is my first time and don't really know how long it truly takes. It is probably something I could do myself I bet.
Thats crazy. Last time mine was in, they charged 146$, and that was they're oil, oil filter, and both fuel filters.
They even checked every imaginable fluid, oiled the door hinges and latches with a spray lubricant, checked tires, pressure, tranny, etc, etc ... checked everything.
__________________
Such a cool little toy, for what it costs :
They checked alot of other things, I just didn't list them. $80 to change two fuel filters seems kinda pricey to me, especially since I provided the filters.
However, you might try your local quicklane instead for some of these items. Mine is in a separate building and so I see them for the simple stuff. Seem to have their own pricing and the guy is very down to earth. Find Quick Lane Tire & Auto Centers
so the 6.4's loose coolant some how that is acceptable? i test drove one last week. it was low on coolant, i asked them to check it out they said they pressure tested it and it was fine. but i'm scared to pull the trigger on it.
__________________ SHAWN :PAA# 102 --
2012 F250 CC Lariat FX4 / White Platinum / 3.55e
2009 Outback Sydney 310BHS Gone but not forgotten--2001 / 7.3L / 2wd / CC/ lwb / manual trans / dually / 160K
Mine's been losing coolant since I got it, after multiple pressure tests etc, they think it's the head gasket.
One of my friends had the same thing happen to his stock 6.4.
Losing coolant a little then one day HG let go.
But there is a lot of ways one of these trucks could lose coolant.
__________________
Mine was short maybe by like a third of a gallon. I bought it used and it was that way, didn't seem like a big deal to me as the truck only had 30,000 miles on it. I put a new degauss pressure cap on too a couple weeks ago.
Sounds very familiar.
I was always losing coolant, and nobody wanted to look into it any further. I always assumed it was a leak, and kept trying to trace down leaks, and I think it was the head gaskets all along.
Right now, I've put 4000 km's on it from when i got it back, and the coolant level hasn't changed a millimeter. It's exactly where it was when it left the dealership, and I know, cause I marked the level with a marker.
It's never stayed level that long, and the dealership never even changed any parts out.....
__________________
Thats good to know. I will definitely keep an eye on it then.
