Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 04-24-2012, 03:23 PM
GB SISSON's Avatar
GB SISSON GB SISSON is offline
Garage is empty, add now
GB SISSON is gaining momentum as a positive member of FTE.GB SISSON is gaining momentum as a positive member of FTE.
Electric Wiper Options
I need to convert to electric wipers as diesel engines don't create vaccuum. I saw a kit a while back but don't remember if it works on a fridge and cost is a concern too. I would rather find something out of the wrecking yard I could adapt. Does anyone know what I should be looking for? Thanks, GB
__________________
'92 F350 4x4 dual wheel service truck. 7.3 with headers and glass packs. 5 sp man tran. 255 85 16 Toyos. 110,000 miles. '59 F350 9' flareside new project, cummins 6at turbo diesel, sm 465 4 spd. 255 85 16s again, 37 ford 1 1/2 ton stake with 53 flathead V8. 65 toyota landcruiser fj 45 longbed pickup. 54 GMC 3/4 ton flatbed w/ cummins 6at, '68 BSA 441 Victor Special, bone stock, Antique tractors and one lung flywheel engines .....
  #2 (permalink)
Old 04-24-2012, 08:39 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
Sunshine!
  #3 (permalink)
Old 04-24-2012, 08:51 PM
GB SISSON's Avatar
I think Wally Theodore/teddy has the corner on that market........ Pouring here.
__________________
  #4 (permalink)
Old 04-24-2012, 09:24 PM
theodore/teddy's Avatar
theodore/teddy theodore/teddy is offline
theodore/teddy is starting off with a positive reputation.
GB it was a beautiful sunny day here. However we could use a little of your rain.
I have seen a couple of after market wiper motor kits, but your right they are kinda spendy! Got to be one waiting for you at the doaner yard!
__________________
Looking for an in bed spare tire mount for styleside fridge bed.
1959 F250 4x4
Wally
  #5 (permalink)
Old 04-24-2012, 09:56 PM
GB SISSON's Avatar
I can't help thinking I saw a post about one fron an 80's jeep cherokee or something like that and all you had to do was elongate a couple of mounting holes. That's easy for me... I do that even when I'm going for an exact center. Also, does the vaccuum motor turn in a circle like an electric motor with some kind of 'back and forth transmission' added or does the vaccuum motor work with a back and forth 'paddle motion' like a model A?
__________________
  #6 (permalink)
Old 04-24-2012, 09:57 PM
MARC's Avatar
MARC MARC is offline
1959 Ford F-100
MARC is starting off with a positive reputation.
Electric one in junkyard in Showlow Az. Called Showlow auto salvage. They have 1960 F-100 4x4 in yard. I will be there next month if interested
  #7 (permalink)
Old 04-24-2012, 10:33 PM
GB SISSON's Avatar
For sure! My '65 toyota fj 45 pickup came from Show Low. Other than that I never heard of the place. I never drive it in the rain so I still don't have the wipers hooked up on it! This was sitting behind a guys place in Show Low for 26 years with no engine or tranny, I found it and updated it with later LC gear from a rusty hulk.Thanks for the heads up on the wipers and I'm definately interested. Will be out of touch a couple days, then I'll get the details.!
__________________
  #8 (permalink)
Old 04-25-2012, 09:41 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
You will need more than just the electric wiper motor to convert from vacuum to electric wipers.
Vacuum wipers: The R & L wiper arm pivots and the arms that connect to the motor are one piece assemblies.
Electric wipers: The R/L pivots are separate from the R/L arms.
The switch is also different.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #9 (permalink)
Old 04-25-2012, 05:30 PM
mcdonaldm mcdonaldm is offline
mcdonaldm is gaining momentum as a positive member of FTE.
i used an electric motor and switch (and the intermittent wiper option) from a mid 70's truck. you have to buy the electric wiper motor link ***'y from someone like Dennis Caprenter of LMC (pretty cheap price)to make it work with the stock linkage arms, but it works pretty slick. had to make a new plate out of aluminum, but that is pretty easy to do also.
i also looked at using a mid to late 60's ford truck setup as it puts the motor inside the cab, but i decided to go the above route. not sure if it would work, but looked like it should with a bit of modification.
that is the route i took.
rgds
Mike
  #10 (permalink)
Old 04-25-2012, 07:53 PM
85lebaront2's Avatar
85lebaront2 85lebaront2 is offline
Old School Hot Rodder
1986 Ford F-350
85lebaront2 has a great reputation on FTE.85lebaront2 has a great reputation on FTE.85lebaront2 has a great reputation on FTE.85lebaront2 has a great reputation on FTE.85lebaront2 has a great reputation on FTE.
william.a.vose
I found one on an F600 in a junkyard that had a double crank arm, the one closest to the motor worked one side, then the second crank arm attached to it and passed back over to the other side, the result was the wipers worked in opposition very nicely. I later added an intermittent governor and switch to it so I had intermittent two speed wipers on my '58.
If you find one, I think I still have the dash switch and plate for the '58 original two speed.
__________________
Bill Vose (Old School Hot Rodder)
1986 F350 crew cab DRW 460ci EFI, E4OD, PMGR starter, 160 amp 3G alternator, 12X3 rear brakes, Traction lock 3.55
1995 Lincoln Continental (project car), 1994 Taurus LX (daily driver)
http://www.oldschoolhotrodder.com
"growing old is inevitable, growing up is optional"
Last edited by 85lebaront2; 04-25-2012 at 08:03 PM. Reason: additional information.
  #11 (permalink)
Old 04-25-2012, 09:19 PM
Rusting-Nuts's Avatar
Rusting-Nuts Rusting-Nuts is offline
1960 Ford F-100
Rusting-Nuts is starting off with a positive reputation.
There is a thread on here somewhere about using a wiper motor from a late 80's Ford Ranger or Bronco II. It looked pretty easy to do I think he even added the delay feature. If I remember correctly he just fabbed up a mounting plate to mount the motor And had to play with the lenth of the arm on the motor to get the sweep of the arms right. I am sure with your fabrication skills you will find it quite easy to do. I have plans do this mod my self at some point. Good luck
Jack..
  #12 (permalink)
Old 04-26-2012, 07:58 PM
GB SISSON's Avatar
Just got back from an exausting trip and will digest this info. I really appreciate the help and info all of you have offered! My thing is the front clip is off for now and it's really accesible, so I want to nail this down before I re attach the front clip., At 59 years old, it's sooo much easier to work in the engine compartment when you can reach all this stuff standing next to it. BTW the trip was a mix of my looking at a job down in Seattle for me ( more work)and going with a chev truck buddy to look at a 55 short bed from the grandson of the original owner that was bought and always lived in the mohave desert. Even though it was GM , the truck part was way more fun than the work part. DUH.
__________________
  #13 (permalink)
Old 04-26-2012, 09:23 PM
Walston's Avatar
Walston Walston is online now
1960 Ford F-100
Walston has a good reputation on FTE.Walston has a good reputation on FTE.Walston has a good reputation on FTE.
I installed a ranger wiper motor in my truck, see my gallery for details.
__________________
Walston
http://bigjohnstractor.com/
  #14 (permalink)
Old 04-27-2012, 10:31 AM
GB SISSON's Avatar
Walston, I was unable to find any info about wipers or any truck info on your link. I enjoyed the pictures though. Maybe I don't know how to navigate it correctly.
__________________
  #15 (permalink)
Old 04-27-2012, 12:27 PM
manglass manglass is offline
manglass is gaining momentum as a positive member of FTE.
I used a N.O.S. motor, wiring harnes, and switch from Job Lot Automotive (expensive, but worth it) along with the link from Dennis Carpenter to convert mine. It was all bolt-in, the wipers work great and the only thing I had to do was run a power wire. I took the opportunity to add an 18 fuse panel/distribution block under the dash and out of sight to handle any future additions.
Lou Manglass
Tags
1960, 37, conversionfor, electric, f100, ford, general, install, int, motor, powered, tractor, truck, vbulletin, wiper
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
