Old 11-24-2014, 06:10 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Electrical Guides
Print Wikipost
351M starter replacement
Old 04-24-2012, 01:32 PM
78fordwheelin's Avatar
78fordwheelin
78fordwheelin is offline
Went out to my truck this morning, and all I got was a click when i turned the key. So looks like its time for a new starter. I was gonna pull it and go get a new one real quick, But i cant figure out how to get the top bolt out. The truck came with headers and they couldnt be any more in the way.
Anyone else with headers on their 351 know any way to get to it other than taking the headers off?
Old 04-24-2012, 02:39 PM
bkohne1's Avatar
bkohne1
bkohne1 is offline
I have the same motor (with headers) in my 77 f250 and I am able to reach the bolt closest to the engine from underneath and the other bolt (closest to the frame) from the top side.
Old 04-24-2012, 05:24 PM
mark a.'s Avatar
mark a.
mark a. is offline
Did you check your battery ? Try beating on the end of the starter with a hammer if jumping it doesn't work. If you get it running check the charging system, see if it's putting out anything.
Old 04-24-2012, 07:27 PM
JBradley500's Avatar
JBradley500
JBradley500 is offline
What's clicking? Is the solenoid clicking?
Old 04-24-2012, 07:33 PM
78fordwheelin
Gave it a good beat, tried jumping it, and tried a different battery that I knew was good. Same result. And yes the solenoid clicks
Old 04-24-2012, 07:34 PM
78fordwheelin
And the alternator is new, although for some reason my headlights pulse when the engine is running
Old 04-24-2012, 07:54 PM
critterf1's Avatar
critterf1
critterf1 is offline
"Jump" the solenoid and see if it starts.
Old 04-24-2012, 08:07 PM
78fordwheelin
Can I jump it from the wire that attaches to the relay? I can't fit jumper cables past the headers
Old 04-24-2012, 09:51 PM
hasteranger's Avatar
hasteranger
hasteranger is offline
I think he is saying jump it right at the solenoid. I usually just use a screwdriver or two to test the solenoid. Just don't use one you like a whole lot, it can melt the end. lol.
I had a 351 and now a 460 and I have no problems getting to the bolts with a standard wrench. i can't get a ratchet on either on, but I can get a wrench. I do not have headers, though.
Old 04-24-2012, 11:02 PM
cdntthinkofausername's Avatar
cdntthinkofausername is offline
extension and ratchet i thought it was impossible to but it just takes a long time
Old 04-24-2012, 11:58 PM
78fordwheelin
how do you test it with a screwdriver?
Old 04-25-2012, 10:37 AM
hasteranger
This is the general technique, I'm using a pry bar instead of a screwdriver on the battery because thats what I had laying around when I walked outside:
And this is the likely consequence for your screwdriver, although this is a cheaper than dirt one I keep in the toolbox for just such a purpose (one of my trucks had a finicky solenoid for a while):
Old 04-25-2012, 11:03 AM
78fordwheelin
Ohhh okay so you just use the screwdrivers to jump the battery positive to the output on the relay? Its kinda hard to see on my phone but that's what it looks like
Old 04-25-2012, 04:06 PM
monsterbaby's Avatar
monsterbaby
monsterbaby is offline
if your going to directly bypass the solenoid use jumper cables. attach to the output side of the solenoid and then other end to the positive of the bat.
Old 04-25-2012, 10:13 PM
hasteranger
Too cumbersome. Use jumper cables and youre likely to short them out against the fender. From experience. Just use screwdrivers. They are just as thick and conduct 12 volts just as well as jumper cables, and they will flow more than enough current to start the truck .
Quick Reply: 351M starter replacement
