Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty & Heavy Duty
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Super Duty & Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
  #1 (permalink)
Old 04-24-2012, 10:19 AM
G1vemtheboot G1vemtheboot is offline
Garage is empty, add now
G1vemtheboot is starting off with a positive reputation.
Help - Engine "rocking"
This may already be in here but I didn't see it anywhere...
I have a 2000 F250 SD, this morning the engine started rocking, when I'm in drive holding down the brakes it keeps rocking forward like it wants to take off. It does the same thing in park, but it doesn't move the truck as much as in drive. Seems normal when I have my foot on the gas.
  #2 (permalink)
Old 04-24-2012, 11:11 AM
update
After some more research I'm not sure if this is correct or not, but maybe idle surge? Where is the PCV system so i can look for hoses with cracks? any help would be greatly appreciated!
  #3 (permalink)
Old 04-24-2012, 11:30 AM
SuperDutyScaler's Avatar
SuperDutyScaler SuperDutyScaler is offline
SuperDutyScaler has a good reputation on FTE.SuperDutyScaler has a good reputation on FTE.SuperDutyScaler has a good reputation on FTE.
in gear the motor makes the trans push the truck? That sounds like a bad TQ converter. Does the idle jump at all, could be a bad Idle Air Control valve
__________________
2004 F-350, XLT, SC, SB, FX4, 5.4, 4R100 w/ TransGo HD shift kit, 4.30 gears w/ stock LS, SCT X3, zoo dad mod w/ STOCK intake, Gibson stainless headers, SPD y-pipe, 51509 cat, Borla exhaust, 1" rear AAL, dually upper and lower overload spring, 08 diff cover, ProComp 22210 springs, more.....
  #4 (permalink)
Old 04-24-2012, 01:26 PM
The idle does jump up and down, but the tach doesn't move up or down
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
