the official OBS diesel off topic thread
Elastomeric comes in a couple different brands. They are all about the same. My rubber roof only covers up to the edge of the roof, not over the edge. They then put a caulk around that which over time started leaking. I found this 4" wide tape, super sticky stuff and put it over the caulked seam then painted it with elastomeric. I put a coat on every year and it has never cracked or leaked. I also used that tape around the vents, ac, tv antenna, etc. and painted elastomeric around them. My wife breaks out with mold so it was very important to stop all leaks. We have had some plumping leaks but that's another story!
The cheaper commodity grade stuff is watered down and has lots of fillers that won't age well.
on
1 Post
Actually elastomerics are nowhere near the same, even among the same brands. There are commodity grade to professional grade products that vary greatly in quality. The key is to get the high grade stuff in whatever brand you go with.
Is there a problem with the seams failing or coming loose? If not, I wouldn't worry about it. If the material is starting to show signs of age, then coating the entire thing will protect it from the UV and help extend the life.
No sir. Just thinking preventative. If I don't need to do anything, then I certainly won't add more work to my plate. Thanks Chris.
Got to Omaha to see the grandkids and haven't done a thing to the truck, no time. I just left my key in there in the unlock position and used my wife's key to lock the truck. Haven't started it for a week now, been using the Geo. My guess is to pull the ignition switch, blow it out, clean everything up then put graphite on the out side of the ignition switch and inside. Maybe someone will come along and say the proper way.
Happy Sunday fellas...what's everyone up to this beautiful day? Weather is good here, no moving cows or working horses today. I am thankful for that since I need a break. We have been going ninety to nothing for weeks! We are headed down to Ft. worth for a little time wirth the grandparents for my daughter and some Cooper's Pit BBQ with a lot of cold Shiner. I still haven't changed my fuel filters, but that's going down in about 30 minutes before we pull out for the day. Hope you guys are all enjoying the day and dodging the Spring rains. We have had a TON down here. Some of our lakes that were 37 percent are now to full capacity! Crazy....and that's your rancher's almanac report for the week...LOL!!
on
1 Post
