the official "the I should be working on my truck instead of typing thread" - Page 695 - Ford Truck Enthusiasts Forums
Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Sign In
Register Forgot Password?
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
  #10411
Old 08-01-2014, 11:55 PM
fordman67 fordman67 is offline
fordman67 has a very good reputation on FTE.fordman67 has a very good reputation on FTE.fordman67 has a very good reputation on FTE.fordman67 has a very good reputation on FTE.
Quote:
Originally Posted by FI460 View Post
Maybe ask Brad. He always talks like theyre a dime a dozen.
Rather eat a turd.
  #10412
Old 08-02-2014, 03:08 AM
stainlessstroker95's Avatar
stainlessstroker95 stainlessstroker95 is offline
stainlessstroker95 has a good reputation on FTE.stainlessstroker95 has a good reputation on FTE.
JP, are any relation to Bill? Haha. Glad you had a good trip with out any issues Nate. Now time to get in the shop and get the truck acting right.
__________________
Gabe 95 f250 4x4 super cab psd, zf 5 speed, 6637 air intake, scan gauge, stancor gpr, ccv mod, 140v IDM, HPX line, irate t4 mount, s366 turbo, i/c, 3" plenums, Rosewood 238/80 hybrids, T500, studs, springs, rods, DP Tuner f6 chip, diamond eye ss 4" exhaust, 3" dp, irate e fuel, short throw shifter, Valair kevlar/ceramic clutch, Destination MTs, d60 RSK V codes , shackle flip B codes, bilstien shocks, scorpion bed liner, custom tailgate. 96 f350 4x4 psd, dually flatbed welding truck, zf 5 speed, stock. 79 bronco.
  #10413
Old 08-02-2014, 05:43 AM
liftnw8z's Avatar
liftnw8z liftnw8z is offline
Team Brahma
liftnw8z has a superb reputationliftnw8z has a superb reputationliftnw8z has a superb reputationliftnw8z has a superb reputationliftnw8z has a superb reputationliftnw8z has a superb reputationliftnw8z has a superb reputationliftnw8z has a superb reputationliftnw8z has a superb reputationliftnw8z has a superb reputationliftnw8z has a superb reputation
liftnw8z Bill_SoonerFan
Quote:
Originally Posted by martin72 View Post
We need pics please!!!!!!!!!!!
I will try and post some when I get home Sunday .
__________________
Bill - PA Chapter Member
'98 F150 4x4 5.4L "Brahma Bull Edition" <--- Build Thread
'96 F350 CCLB 4x4, 7.3L "The tOwBS" <--- Build Thread
'98 Expy EB
2015 Show Schedule will support #22NeedsAFace
  #10414
Old 08-02-2014, 06:57 AM
oldbird1965's Avatar
oldbird1965 oldbird1965 is offline
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
Glad you had a good trip Nate!
__________________
Glenn The Mule-96 2WD F250 EC/LB auto PSD
The old gray Mare 97 dually cc,modified s366 turbo,stage II's,DI IC,studs,springs,rods,JW auto,4:10 LS,air bags,SD uvch,efuel,FS2500 bypass oil filter,HVHF IDM,IH WP,6.0 trans cooler & rad fan,MBRP 4",SD tensioner,AFE air filter,220 amp alt,38 gal rear tank & 33 gal aux bed tank,aux oil cooler,soundproofed,4 tuners on Hydra,ac cold mod,XS batteries,riffraff hpop reservoir,aluminum radiator,Adrenaline hpop, water injection
  #10415
Old 08-02-2014, 09:28 AM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
Quote:
Thanks guys.
You got that right Gabe. I do need to get into this thing and see what I can do to make it run like it should. I think I may order a set of injector o-rings and put another set of injectors into the truck (that someone was kind enough to loan me) and see what happens.
Then again, I may be just about to bite off another little "project"....
Oh, and my shop just inherited a Subaru in about 200 pieces. Waiting on someone else to get their poop in a group for that one to get done as well. It may have to go outside for a while.
__________________
--Nate "Just a redneck geek"
1997 F-350 7.3 PSD, 4x4, CCLB SRW, 3.55's, ZF5
If it isn't under warranty, I'll fix it myself.
  #10416
Old 08-02-2014, 10:26 AM
tshrager's Avatar
tshrager tshrager is offline
tshrager has a good reputation on FTE.tshrager has a good reputation on FTE.
Quote:
Originally Posted by DIYMechanic View Post
Thanks guys.
Just come here early next sat, we can re wire my house, then do sticks on sun!
__________________
Todd
96 F350 4x4 PSD, CCLB, E40D -> ZF5, 4.10ls, Riffraff 6637, 3" DP to 4" straight pipe, SD 17*, Autometer Phantoms, BTS tunes, 180/80 stage II's, DIY/Rebilld E Fuel, Aeroforce Scan Gauge
On The Shelf - Intercooler/pipes 350-380HP on the Travis Dyno
  #10417
Old 08-02-2014, 02:49 PM
El Camino Man's Avatar
El Camino Man El Camino Man is offline
El Camino Man is a splendid one to beholdEl Camino Man is a splendid one to beholdEl Camino Man is a splendid one to beholdEl Camino Man is a splendid one to beholdEl Camino Man is a splendid one to beholdEl Camino Man is a splendid one to beholdEl Camino Man is a splendid one to behold
Im over the whole dealership experience. I wouldn't go to them but I typically cant find what Im looking for outside a dealership and I typically need to trade something in.
If I had the choice between getting a junkyard 7.3 and fixing my current one, id rather fix my current one. The only problem is Im no good at diagnostics lol. If I 100% knew what was wrong with it, Id just fix the dern thing lol
__________________
-2003 Excursion Limited, Quad Captains, Mineral Gray, 6.0L, 5R110, 4wd, Cen-Pe-Co Additives, EGR Delete, Straight Pipe, Coolant Filter, 250,000 mi
-1996 F-250 PSD, XLT, ECLB, 4wd, E4OD, 4.10s, 6637, 3" DP Dump, Tuned, 400,000 mi
-2015 Yamaha TW200 - Warm Weather Machine
  #10418
Old 08-02-2014, 03:13 PM
I forgot to mention, I had a job opportunity come to me. An older guy I work with bought himself a Super Bee in Mooresville, NC and needs a way to get it home. I mentioned I could prolly go get it for him and he got kinda excited lol. I mapped it out with google and its around 950 miles. Not "too" bad but after my trip to RRE.... idk lol. Im sure that car plus a trailer would really dog the ol 7.3 down plus my pizza cutters, plus interstate speeds, plus mountains...
I guess I could go out and try to find myself the biggest used tires I can and put em on the rear axle lol.
Funny thing is, no matter which route I take, I will drive right by the Newport KOA lol
__________________
  #10419
Old 08-02-2014, 03:36 PM
With the smaller tires you're running I'm sure you could get that car and trailer home just fine. Just take your time and don't get in a hurry and you'll be just fine. I have towed quite a few cars on trailers with my truck in stock form and I haven't had a problem towing them. With your 4.10s and pizza cutters you should have even better gearing for towing them. I would tend to avoid the WV Turnpike (77) and the associated steep pulls if you're worried about the weight, but it really shouldn't be a bad pull for you. Heck, you could make a long weekend of it and stay at the KOA a couple nights.
And Todd, do I take that to mean you're ready for wiring? My offer to help still stands.
__________________
  #10420
Old 08-02-2014, 04:37 PM
Well bring that thing over jp and let's tear it down and see what it looks like. I will pull my psd off the stand and we can get down to it. I'm not doing anything on my engine build anyway for a long time.just too lazy to take it off if no reason.
__________________
1996 f-350 cclbsrw4x4 psd build it yourself and save
d.i.y. efuel with gsl392 and aeromotive regulator. t-500,6.0 IC ,d.i.y. s468 turbo & kit, flat plenums. 225/100 stroked a code rosewoods, head studs,smith bros push rods,comp springs,4" recycled,used,reclaimed exhaust. just a collection of trash repourpsed.
sky 3" rsk with bilstein 5125 shocks
and a bunch of crap my wife does not need to know about lol
  #10421
Old 08-02-2014, 05:02 PM
cowmilker08's Avatar
cowmilker08 cowmilker08 is offline
cowmilker08 is gaining momentum as a positive member of FTE.cowmilker08 is gaining momentum as a positive member of FTE.
FordTough7.3DIT
Man, I wish you guys lived closer to me. Sounds like a blast! I love working on PSD's.
__________________
-Phil, '96 F250 7.3L, E4OD, 4x4, 3.55 gears, DIY intake, EBPV gutted, 3" DP to 3-1/2" SP, 203° T-stat, 1.0 Turbine Housing, 288 kmi
'97 F250HD 7.3L XCLB, E4OD, 4x4, 3.55 gears, 3" DP to 4" SP, EBPV gutted, DIY Intake, 125 kmi
"He that hath the Son hath life; and he that hath not the Son of God hath not life." 1 John 5:12
  #10422
Old 08-02-2014, 06:11 PM
I'll be up that way for labor day phil
  #10423
Old 08-02-2014, 07:07 PM
madMatador78's Avatar
madMatador78 madMatador78 is offline
madMatador78 is gaining momentum as a positive member of FTE.
gibby.1989 tombombadom tombombadom tombombadom
We can have a psd party/torque flite party. Lol! Make a weekend of it.
__________________
Thomas
1997 F-250 XLT HD CCSB 7.3 PSD E40D 4X4 376K and counting!
1988 F-150 XLT Lariat RCLB 302, AOD, 4x2
And too many others...
  #10424
Old 08-02-2014, 07:19 PM
BBslider001's Avatar
BBslider001 BBslider001 is offline
BBslider001 is gaining momentum as a positive member of FTE.
Well, with all this engine talk going on, I had to post a few photos for my own well-being. A few new truck parts and some summer days we've had these last few weeks. I missed RRE, but I guess life isn't all bad.
New truck parts from Clay! Gave me about 4-5 pounds of boost! Think my other ones were bad?
California sunsets
Fire walking
Fire started for the evening after a long day of surfing
Good night!!
__________________
Byron
1997 F-350 CCD-PSD, 6637 Intake, 4" Stainless Exhaust, 3" DP, Uppies and E-Fuel by Re-Billd, EDGE CTS, Glow Shift FP/Boost Gauges, John Wood E4OD HD, EBPV Deleted Pedestal, TS Chip, 230k Miles
**Exiss 6-Horse Gooseneck, Front Tack/Sleep Area
**2011 34' Sundance by Heartland TT (10,700#)
  #10425
Old 08-02-2014, 10:11 PM
tshrager's Avatar
Getting very close now. I've finally gotten some help and it's amazing have much faster things have started to fall into place. If the framing is wrapped up either tomorrow or the early part of next week, it's on to the Romex.
__________________
Todd
Similar Threads
"Spinning your wheels" timmyboy76 1999 - 2003 7.3L Power Stroke Diesel 0 03-21-2015 11:14 AM
Another aftermarket thread run6.0run 6.0L Power Stroke Diesel 37 02-25-2014 02:16 AM
Another "weird engine noises" thread JustAJ 1997 - 2003 F150 7 02-09-2014 12:31 AM
Tags
atr, cooper, country, dang moderators!!, drum, line, mash, mekka-hiney-ho, mekka-lekka-hi, powered, set, song, taters, thingamahoochie??, whatchamacallit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.8.7 AC2
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
vbulletin Admin Backup
