the official OBS diesel off topic thread
Ahhhhhhhhh! does it ever stop? I thought I was almost done laying out money.. Now there's another 300 bucks! Gonna have to go rob the wife's purse.
on
1 Post
Doing the springs and push rods isn't a bad idea at all. Whether it is absolutely necessary or not, I don't know. Travis and talked briefly about this one day. The head studs I'd say are a must because of the boost levels you can hit. As far as the springs and push rods go, as long as you don't over rev the engine, you should be fine, but honestly if it were me, I would go ahead and do them. I guess I just assumed you were doing them since you were doing the head studs. Didn't think to ask
on
1 Post
My old valve springs were iirc about 40lbs less seat pressure than the new ones. Some of that is the new ones are higher, and some is just age and use on the old ones. The pushrods at this age need to be upgraded too. One accidental high rev can bend a pushrod, seen it happen.
Have you gotten ahold of Tony for your tunes? You'll want to get them tweeked too for the turbo, and head studs. He wants to know if you have studs when you order from him, I suppose he "gets after it" a little more if you are built for it.
It'll end eventually, you just have to make it end!
