the official OBS diesel off topic thread
Old 08-13-2014, 04:48 PM
BBslider001's Avatar
BBslider001
BBslider001 is offline
Originally Posted by El Camino Man
I don't see the problem lol.
Buy the truck and Aaron's bronco and ya got yourself a project!
Speaking of projects, has anyone else seen the completion of project Super Dually on (formerly) Trucks!? I... Want... It...
yeah, I watched that a few days ago! I have been waiting for 2 years to see the completion of that thing. It.....is.....epic!!!!
  #10592
Old 08-13-2014, 06:43 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
  #10593
Old 08-13-2014, 06:44 PM
liftnw8z's Avatar
liftnw8z
liftnw8z is offline
(CL) Team Brahma
Originally Posted by ReBilld
There's so much wrong here - but somewhere someone thinks this is amazing.
  #10594
Old 08-13-2014, 06:45 PM
427 fordman's Avatar
427 fordman
427 fordman is offline
OMG.
10 char
  #10595
Old 08-13-2014, 06:51 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
The stacks would have been too much on their own......but since he put the tow mirrors on there too, it all came together...........
  #10596
Old 08-13-2014, 06:52 PM
liftnw8z's Avatar
liftnw8z
liftnw8z is offline
(CL) Team Brahma
Tow mirrors fix everything!
  #10597
Old 08-13-2014, 06:59 PM
fordpride's Avatar
fordpride
fordpride is offline
That what happens when a obs PSD rear ends a fox body
  #10598
ReBilld's Avatar
ReBilld
ReBilld is offline
LOL!!!!!!!
  #10599
Old 08-13-2014, 07:00 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
Originally Posted by fordpride
That what happens when a obs PSD rear ends a fix body
I guess it could be worse........I'm not sure how, but it could be! LOL!
  #10600
Old 08-13-2014, 08:06 PM
DIYMechanic's Avatar
DIYMechanic
DIYMechanic is offline
I think it need more than the batteries charged. Lol
Yeah, I don't think that's going to buff out....
I'll tell you how in one word!
Cummins.
In other news, I would like to report that engine temperature seems to play little or no significance in the results of a compression test. Last night I tested 6 of the 8 holes in the engine in parts truck '14 before the grease gun tube popped (or at least I thought it did). I only had cylinders 6 and 8 left to do when I heard a loud "POP!" and the last two results were a lot lower. Replaced the hose tonight and completed the test on holes 6 and 8 and the retested the other 6 just for the sake of comparison. Absolutely no difference in readings. None. The first test was run with an EOT of 170* and tonight I finished it with the engine at about 72* ambient. No difference in readings on any of the holes. I'll test the engine in my truck as well and compare those results once I get my injector o-rings in the mail. That will be an even better test since I will be able to test at around 170* EOT and compare that to one done when it was about 20* ambient.
Long story short, don't worry about doing your compression tests at operating temperature. All it does is created a hundred places to burn yourself.
Oh and a new hose tonight reveals that the test results on holes 6 and 8 actually are lower than the rest anyway. Go figure.
  #10601
Old 08-13-2014, 08:35 PM
fordman67's Avatar
fordman67
fordman67 is offline
And the survey says???
Its a no go for a swap for in yours?!:-(
  #10602
Old 08-13-2014, 09:37 PM
martin72's Avatar
martin72
martin72 is offline
His other ride is a Cummins. LOL
  #10603
Old 08-13-2014, 10:04 PM
tshrager's Avatar
tshrager
tshrager is offline
Couldn't agree more with how great this place is Byron.
Seriously Bill, I thought you had your fill of mustangs and stacks when you were texting those pics out. I think this is actually your super secret build and you're just testing the waters!!??
Numbers Nate?
On an actual truck note. As some of you know, I smoked an idler pulley at RRE. It still chirped a bit as we replaced it with Gabes (thanks again!) old one. I believe it was still chirping because when it spun itself, it actually cut into the accessories bracket a bit. The pulley itself is now just a hair cocked. As I was putting SCA into the degas bottle this evening, I noticed the belt had skipped a rib and cut a rib. Still operating just fine. The rib that was cut was kinda flopping though. Lol. Threw the spare belt that Nate gave me on (thanks again!) and away I went. Not sure what I'm going to do about it yet. I don't really need the truck but to get materials for the house, I don't have time to work on it, we are less than 10 weeks out for the baby and I don't even have drywall up yet!!! Trust me it's not for lack of effort. I guess I'll do the brake job on my DD this weekend and worry about the truck down the road. Cause I'm sure I'll have nothing but time with a new baby.......
  #10604
Old 08-14-2014, 03:45 AM
stainlessstroker95's Avatar
stainlessstroker95
stainlessstroker95 is offline
And todd called us rednecks up here. You kinda threw him a line there Bill haha. Glad i could help Todd, are you just gonna replace the bracket? If you find a replacement, go ahead and trim it so you can install the sd tensioner mod later on.
  #10605
Old 08-14-2014, 05:57 AM
DIYMechanic
That bring up a good question Gabe, could Todd just install a SD tensioner on this bracket to solve his issue? (well, the issue with is serp belt, at least...) I don't know exactly how the SD tensioner fastens on, but does it need that face that is buggered up?(the one on the bracket, I mean...)
Todd as for numbers I got about 360 PSI on 6 of 8. The other two (6 and 8) must have eaten some dust at one point or another because they're a little lower at about 310 and 330 each. That's more than the 10% deviation I was hoping to stay within but I guess it's still better than what I'm running now. I plan to test the compression again on the engine I'm running now when I do the injector o-rings and I'll compare the number then. That way I can decide whether the swap will be worth the effort. If the truck runs okay with different injectors an new o-rings in it, I may just keep this PSD on the stand as a spare and run the one that's in the truck until I either can't stand it anymore or it quits. I haven't fully decided what my plans are yet.
Quick Reply: the official OBS diesel off topic thread
