Correcting the Speedo in 2000 Excursion with 7.3L
Who/what is AE?
I purchased and just received a SCT Livewire 9600 Programmer/Tuner. However, there is no setting for tire size or axle ratio when selecting the 7.3L Diesel.
AutoEnginuity.
Riffraff Diesel: AutoEnginuity Total Ford Enhanced Bundle
You have my condolences.
Stewart
The ScanTool package consists of:
-AutoEnginuity's software
-AutoEnginuity's OBD-II vehicle interface (ST06)
-USB 2.0 interface and cable
-User Guide
-Quick Installation Guide
-Available with English, Spanish and German languages
Scan Tool
The package that we offer is the Enhanced Bundle that is for all Ford vehicles. It will allow you to run the common tests on your Powerstroke that can only be done with a fully enabled scanner such as AE.
AutoEnginuity's Scan Tool is a hardware and software combination for Windows ME / 2000 / XP (Pro, Home, and Media Center) / Vista / Windows 7 operating system.
AutoEnginuity's Scan Tool was designed to be as easy to learn—as it is powerful. Scan Tool comes with an automated installation process, a complete and comprehensive User Guide, and an easy-to-use interface. You won't have to spend valuable time learning another piece of software, you can focus on what's important—servicing the vehicle.
What AutoEnginuity's Scan Tool can do:
Save, print, read and clear Stored and Pending P, U, B, and C Trouble Codes. Supporting P0 - P9 generic and manufacturer specific codes (including the new lettered codes (e.g., P06A0)
The largest manufacturer specific trouble code library of all PC/PDA-based scan tools (30,000+)
Read and clear Freeze Frame data
View live vehicle sensors in a meter, graph, or grid format
View oxygen sensor live data and test results
View all 11 Inspection/Maintenance systems and Mode 6 data
Unlimited logging of live vehicle sensors in TXT, XML, or CSV (1ms logging accuracy)
Playback your data logs for offline analysis
Run and query specific component and system tests. Support for generic and enhanced bi-directional tests
View generic and manufacturer enhanced data on the same tool
English or Metric (SI) units of measure supported
Configure your sensors' ranges, scaling value, audible alert triggers, units, and sampling rate
Savable configurations. Set up the interface to suit your preferences and save it so you never have to do it again
Supports 1996 and newer passenger vehicles, whether it be domestic, Asian, or European.
SAE interfaces: J1850 (PWM and VPM), ISO-9141-2, ISO-14230 [KWP2000], and CAN [11bit and 29bit] with the addition of your chosen bundle.
Something we offer that the others don’t:
True Plug-n-Play USB 2.0 interface
Factory scan tool options available
All generic scan tools can only access the powertrain, no matter what SAE Modes (J1979/J2190) they use for communication. With our expansions, you can access dozens of systems (ABS, transmission, GEM, SRS/Airbags, Instrument Cluster, etc.) generic scan tools can't even see. This gives you access to thousands of sensors and dozens of bi-directional controls/system tests. Click here to see our enhanced support for Ford, GM, Chrysler Toyota, Mazda, Nissan, BMW, Land Rover, Honda, Subaru, Mitsubishi, Isuzu, Porsche, Mercedes, Hyundai/Kia, Jaguar , and Audi. Click here for complete enhanced option details.
Optional enhanced expansions allow you to communicate with vehicles like the Powerstroke, Duramax, and Cummins diesels.
Bi-directional support. You have the ability to initiate system and component tests
Mode 6 support. If a system test fails, now you can see the results from the failing component; not just the system. Our Mode 6 data is fully translated so you don't have to waste hours looking the scale and definitions.
Mode 9 support. Full ECM information including CAL, CVN, and VIN reporting
Support for CAN and even the CAN 6x Mode
Support for the new extended sensor list (233 sensors--supporting the SAE J1979 May 2007 additions)
ALL the OBD-II vehicle interfaces in a single cable, rugged case. This is a savings of hundreds of dollars over the competitors' units
-User Guide
Scan Tool
Stewart
AutoEnginuity.
Stewart
Stewart
I purchased the SCT so that I could monitor the truck, make adjustments, and get a few DP-Tuner tunes. Saw a lot of good stuff on this board about DP-Tuners.
I actually like the Livewire and almost bought one for my Lightning. It's just not the "popular" choice for diesel rigs.
Stewart
Thank you Stewart. Is Robin the username I would PM? I haven't been around long enough to recognize real names yet.
I still live in the day where we had to change the speedo gear on the end of the speedometer cable of my 5.0 whenever we did a R&P gear change.
I continually make this same mistake. Ugh.
Stewart
