Susension lift kit for 71 f250? - Ford Truck Enthusiasts Forums
Old 04-24-2012, 02:03 AM
lilsmokey's Avatar
lilsmokey lilsmokey is offline
lilsmokey is starting off with a positive reputation.
Hey all!
Im lookin to lift um my truck a little bit so it isnt so low to the ground. Its a 1971 f250 2wd lwb. I want to get anything around a 4 inch suspension lift or a 4 inch body lift. I dont remember where i was searching but i found a 4 inch body lift for $250 but i cant find it for the life of me.
Any body on here have a similar lift kit for under $500? Im on a pretty tight budget so any help will be appritiated. Thanks!
Edit:
For a 2wd truck that will soon be a prerunne is a body lift or suspension lift better in the long run?
Old 04-24-2012, 05:46 PM
napass2004 napass2004 is offline
napass2004 is starting off with a positive reputation.
I would think suspension lift would be better for a prerunner I've seen them for 65 f100 2wd but idk bout the 250
Old 04-24-2012, 08:13 PM
lilsmokey's Avatar
With the f100 and 250 the only problem i would see is the year difference. When ford did the new generation in 68 i believe i dont know how the chassis changed. Other than the twin i-beam suspension on my truck.
Besides that i dont think i woul need to worry about what weight the suspension is for. Since i can keep the old leafs.
Im not the greatest with my chassis an suspension understanding so id appriciate and clarity.
Thanks guys
Old 04-24-2012, 10:15 PM
elgemcdlf's Avatar
elgemcdlf elgemcdlf is offline
elgemcdlf is gaining momentum as a positive member of FTE.
Thanks guys
5th generation is '67-'72. The difference between the '65/'66 chassis is 2" in wheelbase but the rest is the same (parts wise). Prior to '65 they were straight axles up front. 6th generation is '73-'79 & once again the wheelbase stretched another 2". In addition the rear frame section widened out from the 34" of previous years. There is a split where the widening occurred. I do not remember of it was 250's or 4x4's.
Old 06-27-2012, 12:48 AM
BradyCouchman's Avatar
BradyCouchman BradyCouchman is offline
BradyCouchman has much to be proud ofBradyCouchman has much to be proud ofBradyCouchman has much to be proud ofBradyCouchman has much to be proud ofBradyCouchman has much to be proud ofBradyCouchman has much to be proud ofBradyCouchman has much to be proud ofBradyCouchman has much to be proud ofBradyCouchman has much to be proud of
the body lifts are only if your steering box is infront of the front tires, it is in the small print. body lifts are really only good for tire clearance and i would say should only be 1 inch at max. i posted more about lifts if your other thread.
Trying to find lift kit for my 1990 F 250 pigmanf250 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 03-09-2015 12:35 AM
Body lift? Pros and Cons Mustangking1 1973 - 1979 F-100 & Larger F-Series Trucks 4 09-08-2013 04:02 PM
Lift Kits 2001f1505.4 1997 - 2003 F150 19 04-26-2013 02:28 AM
Pics of lifted 2wd? Shwan_89HD 1987 - 1996 F150 & Larger F-Series Trucks 92 01-13-2012 11:43 PM
lift kit ?s metalskater2 1973 - 1979 F-100 & Larger F-Series Trucks 6 07-20-2009 01:28 PM
Tags
1971, 2004, 2wd, 71, denver, extension, f100, f250, ford, inch, kit, kits, lift, suspensionin, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
