This is a dumb question about Hubs
My 02 CC DRW was trying to pull a stump out but the tires spun. I went into electronic switch over to 4Hi but still spun the tires. Then I discovered I had hubs after 5 years never getting stuck (have a huge cab over most of the time).
I never switched my hubs to lock but often switched inside the cab to 4h and even 4l. Some one tell me I've never had it in 4x4 until I locked the hubs. If so I feel like a cuckold. I thought the electronic switch was all I needed
Thanks in advance
Sumpdhit
Max
Thanks in advance
Sumpdhit
Max
Even when the vacuum system and hubs are working properly, the auto lock hubs need a short travel distance to engage. The main reason the hubs have a 'lock' position is if you are in 2x4, not moving and need 4x4. The front axle will not engage simply with the dash **** under this condition.
__________________
Specializing in Viton® o-rings and leak repair kits for the 7.3L and 6.0L diesels
(970) 368-4455 aka guzzleguzzle's Mods & Maintenance website
Thanks in advance
Sumpdhit
Max
Thanks in advance
Sumpdhit
Max
I still have the auto hubs.If I need 4hi I normally do not lock the hubs.If I am going to pull something heavy,stuck or great strain I lock the hubs and use 4 low.
