Rebuild kit for Toyo Steering Gear box - Ford Truck Enthusiasts Forums
Old 04-23-2012, 09:34 PM
teardropty's Avatar
teardropty teardropty is offline
teardropty has a very good reputation on FTE.teardropty has a very good reputation on FTE.teardropty has a very good reputation on FTE.teardropty has a very good reputation on FTE.
Well I needed to put a better steering setup in my 1954. The stock box needed rebuilt and I figured I would switch over to a Toyota manual steering box. I chose not to go to the power box because of the hassle with the 223. Anywho... I bought a used box from a salvage yard and had it shipped. When it arrived it was leaking badly. My question is, has anyone replaced the seals in these boxes? Is there a kit available? I hate rebuilding it but the place I bought it from refuses to refund my money unless I ship it back and I need to get a box in my truck. I don't have time to fuss with them right now. Any ideas? Or does anyone have an extra box sitting around they would like to sell?
Old 04-23-2012, 10:59 PM
Dano78's Avatar
Dano78 Dano78 is offline
Dano78 has a good reputation on FTE.Dano78 has a good reputation on FTE.Dano78 has a good reputation on FTE.
Never been through either of the Toyota boxes, but have re-sealed many FoMoCo power boxes. Napa seems to have kits for those available so I'd bet that they would have something for the Toyota box.
Old 04-23-2012, 11:05 PM
bobbytnm's Avatar
bobbytnm bobbytnm is offline
Roast em' if you got 'em
bobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud of
There was a thread a year or so ago about resealing a toyota box. The thread even had part #'s and a source for the parts. I don't remember who posted it or how long ago it was. The search function might turn up something.
I'll poke around and see what I can find
Bobby
added:
http://www.ford-trucks.com/forums/73...ox-repair.html
Old 04-25-2012, 09:29 AM
lordtavo's Avatar
lordtavo lordtavo is offline
lordtavo is starting off with a positive reputation.
I'm currently on the same boat except my box is power and I'm changing my seals just because I don't want any leaks. I spent a whole day researching the seals on mine with a caliper measuring the seals and o-rings. None of the regular autoparts had them listed so I went to the dealer the guy printed me a diagram and with the part numbers I found a few places online that sell Toyota parts for half the price. I remember seeing more seals for the manual box at the autoparts. This write up has the part numbers not sure if they are the same as yours. http://www.oocities.org/zeener96/toyota.htm
I learned there are like 6or7 combinations of seals.
I also found this on here but its for a power box
http://m.ford-trucks.com/forums/show...t=toyota+seals
It has a link for prosteering they have a few kits for the power box. Lastly where is it leaking from my guess would be the sector shaft? When I was looking around I read on some Toyota forums that there are bushings instead of bearings on the sector shaft hopefully your bushings aren't worn I think they are pressed in and require reamming for a nice fit around the shaft. While I was at the dealer the guy showed me the parts diagram for the manual box and remember Seeing 2 bushings on the sector shaft. Good luck with your box hopefully this helps some.
Old 04-25-2012, 06:14 PM
AXracer's Avatar
AXracer AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
Sure the box hasn't been overfilled or filled with the wrong lube? There is no pressure to speak of in a manual box, so heavy leakage is rare. You'd need to check with a Toyota dealer to see what kind of lube is spec'd for the manual box and how full it should be. Just to cover all bases, did you clean the box thoroughly to pinpoint the source of the leak?
Old 04-26-2012, 09:17 AM
maverickman514's Avatar
maverickman514 maverickman514 is offline
maverickman514 is gaining momentum as a positive member of FTE.
check with the toyota gurus over at www.yotatech.com they know all about those trucks and parts
Old 04-26-2012, 06:25 PM
teardropty's Avatar
Thanks everyone for the info. I found a kit at Napa after much discussion at my local Napa. Ax I agree it shouldn't have leaked that much and it may have been from sitting in a plastic bag for so long so it made it seem worse than it was. I will rebuild it next week and post my results. Thanks.
Old 04-26-2012, 10:03 PM
AXracer's Avatar
if you open up your box, be very careful, do it over a large box. If the manual boxes are like the power ones, there will be a fair number of loose ball bearings inside that will fall all over. If you lose any it's all over.
Old 07-15-2012, 10:18 PM
hobbs53's Avatar
hobbs53 hobbs53 is offline
hobbs53 is starting off with a positive reputation.
i got a toyota power steering box kit for my '59 Fridge from CPP. The high pressure hose they sent doesn't have any rubber seal (just male to female, metal to metal fittings). Needless to say, they leak. Anyone gotten the kit from CPP and had the same problem? What can I use to seal the hose ends.
Thanks guys.
Old 07-16-2012, 09:14 AM
jaye's Avatar
jaye jaye is offline
jaye is starting off with a positive reputation.
I don't have any seals in either of my hoses and they don't leak. I've had my setup over 16 years however, the threads are metric, others will seem to fit however they will leak pretty bad. The hose threads should fit pretty snug into the box. I used fitting from the Toyota box.
Old 07-16-2012, 09:55 AM
AXracer's Avatar
There seems to be quite a few dissatisfied CPP customers on here. I suspect they supplied hoses with the wrong side fittings, or someone left the insert part of the fitting(s) out when they rebuilt the box. Look inside the fitting on the box, there should be a brass nipple in there. You need a 16mm reverse flare fitting for the pressure side and a non-standard 17 mm fitting for the return side at the box. Usually the pump end fittings on both lines are 16mm. If you try to put a 16mm fitting in the return port, it will seem to fit loosely, but will leak like a screen door. Don't use any type sealant or sealing tape on the fittings.
Old 07-16-2012, 10:30 PM
hobbs53's Avatar
I haven't tried turning the steering yet; the port on the steering pump (pressure line) is where it's leaking badly...at least at this point...i don't know if the fitting on the box leaks......i've just started the truck yesterday, and noticed a pretty steady drip from the pump fitting.....
yea, i got the steering kit and disc brake kit from them as well as the engine mount kit...;issues with everthing i got....some not so bad...a little grinding here and there, but..............for what i paid for the steering kit/box, i expected it to be turn key..... not a very good experience with CPP
Old 07-17-2012, 02:18 PM
teardropty's Avatar
What kind of pump are you running? Some of the older boxes use a 16mm "O" ring type fitting, not the 16mm inverted flare fitting that comes in the CPP kit. I had to purchase a extra adapter/fitting to make my mid-80's Saginaw pump work right. No leaks. If you are using the inverted flare adapter on a "O" ring style, it will leak due to improper seating. This is what I used.
2012 Allstar Performance Parts And Equipment Catalog
-6 to 16mm/1.5 "O" type P/S adapter fitting
Toyota Steering Box Identifier BigBlueCat 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 06-07-2016 07:34 PM
Steering Box richardgillham 1948 - 1956 F1, F100 & Larger F-Series Trucks 31 08-16-2015 11:19 PM
57-60 Steering box rebuild kit? ahawes 1948 - 1956 F1, F100 & Larger F-Series Trucks 19 06-16-2015 03:20 AM
steering box rebuild cbfomoco 1948 - 1956 F1, F100 & Larger F-Series Trucks 20 04-26-2011 01:47 AM
Steering box rebuild transam525 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 07-20-2008 11:20 AM
Tags
1956, conversion, ford, gear, internet, kit, mobile, motor, needed, powered, steering, time, toyo, toyota, vbulletin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
