Another oil gusher.
Another oil gusher.
I just replaced oil coooler, egr delete, replaced all Orings and gasket in both HPOP, and cooler to include all orings in oil filter housing and its been doing fine. I pulled my boat about miles and it did fine. The next day I hauled it about 10 more miles but had to up a steep hill about 1/10th mile long. Still did fine. The truck sat for about 3 hours and I left (without the boat) to go home. about 3 miles into my 10 mile trip home, I started smelling oil burning and as soo as I smelled it, the oil pressure (factory gauge) dropped to zero then came back up about 10 seconds later. It did that 2 more times and finally stayed flat. EOT was 194 ECT 189 @ 1400 rpm. I limped home with the EOT never going above 194 and as soon as i pulled in the drive, it dumped at least 2-3 quarts on the concrete. Looks like the oil came from somewhere around the oil supply line to turbo. Drain tube is clean, so I don't suspect it coming from turbo unless it came from bottom of the supply line but can anyone tell me if there is enough pressure there to make oil squirt up on tope of the sensors on the oil filter housing?
Thanks
Tim
Thanks
Tim
Thanks. I just go that one out and it looks to be fine. maybe it came from between the oil filter housing and the cover of the oil cooler. IDK?
Oil filter cap .................................................. ................18 lbf/ft 24 Nm
Oil filter housing bolts .................................................. ..11 lbf/ft 15 Nm
Oil filter stand pipe bolt (new) ........................................53 lbf/in 6 Nm
(reinstallation) ..........................27 lbf/in 3 Nm
Oil pan drain plug (see note 3) ........................................18 lbf/ft 25 Nm
Oil pickup tube flange bolts ............................................18 lbf/ft 24 Nm
Oil pump housing bolts .................................................. 72 lbf/in 8 Nm
Oil pressure regulator plug.............................................. 19-21 lbf/ft 26-29 NmOil filter housing bolts .................................................. ..11 lbf/ft 15 Nm
Thanks for the info Benny. This truck is starting to get me frustrated. No one should have the troubles I've had out of a 6.0.
Thanks!!
BTW, I am referring to your OIL PRESSURE SWITCH (the single wire sender that "sends" information to your oil pressure gauge in the instrument cluster) that has likely failed causing oil to leak all over top of the engine, which is also very consistent with your description of your oil pressure gauge dropping out as well. Go to your nearest Ford store to pick up a new sender and replace to fix your issue.
I'm with Mark on this one. You would be far from the first one to have experienced this type of failure very shortly after doing a set of coolers or having everything apart. For this reason, I always remove the oil pressure switch and the EOT sensor from the housing whenever I have one of these apart for cleaning.
The oil level was good but the sensor is 7 years old and is partially plastic. Combined with the heat and pressures it's exposed to, I can totally understand why it would fail. I guess this is pretty common?
Thanks again for you advice. You guys ROCK!!
arkredneck
17
11-16-2014 07:58 AM
indyraven
02-07-2009 09:09 PM
