Cluster Anatomy - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Cluster Anatomy
Old 04-23-2012, 06:06 PM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
Cluster Anatomy
Recently a few threads have popped up concerning adding tachometers to earlier E Vans. This is an autopsy of a typical cluster as found on í97 forward E-Series up to but not including the digital odometer display models. This is intended to be nothing more than an inside look, somewhat demystifying them perhaps, allowing someone to use this for DIY repairs.
Feel free to comment should there be any errors factual, electrically or from your own actual experience. Iíve successfully repaired my own cluster with an inoperative coolant temp gauge but as with most excursions into fixing what was intended to only be replaced the learning curve was a bit steep, at least the first time so ttís not all that horrible.
This is presented as though disassembling the entire cluster and its sub-assemblies is the goal. Some repairs can be done without going this deeply into the cluster---your situation will determine what to remove or disassemble. Some of this may be more than youíd ever want to know; just pick out the info most helpful.
Hopefully this is interesting and/or helpful somewhere along the way. So then we begin:
Typical cluster, clear mask removed, front & rear views:
Photo 1
Photo 2
6 tabs hold the mask to the cluster shell:
Releasing the mask tabs:
Photo 4
Remove all lamps (14 here) and the six 5.5mm screws which hold the cluster shell & face place together:
Photo 5
GENTLY lift the flexible circuit film from these 9 holding posts that double as locating pins:
Photo 6
This film is fairly tough and durable but caution is still important to not damage the solder traces which are just electrical conductors.
There is a PCB mounted to the cluster shell (3 T10 screws) and connected to the flexible circuit film:
Photo 7
The PCB connects to the flexible circuit film here:
Photo 8
Note: Red highlighted areas are locating points, shown for orientation of the different views. The PCB and flexible circuit film are VERY vehicle specific and must remain together in order to maintain the vehicles functions including speed, odometer and transmission shift commands from the ECM.
Three internal wiring connections need to be disconnected in order to continue disassembling the cluster.
First to disconnect is the PCB to the flexible circuit film shown above hightlighted by the black border.
Additional views:
Photo 9
Photo 10
Photo 11
(Arrows show locking tabs accessible as shown in Photo 8 above.
GENTLY lift each side to free the PCB from the circuit film. Two additional connections the the PCB can now be removed:
Photo 12
Flat cable is for the gauge servo assembly; round bundle goes to the speedometer/odometer assembly (shown here separated from the cluster housing cables intact.)
Additional views:
Photo 13
(Above view shows potential problems from mishandling these components; locking tab for the flat cable connector broke away from the PCB. The connection will still be tight but its advisable to be careful to prevent this on the other connections.)
Another view:
Photo 14
[img http://i184.photobucket.com/albums/x268/JWAPhotos/Ford/Cluster/Photo14.jpg[/img]
Once these 3 connectors are loose the faceplate and works of the cluster can now be removed from the shell, shown from the back side here:
Photo 15
(Its not necessary to remove the PCB from the faceplate. Various views show it removed for better camera angles.)
Servo PCB assembly held to the faceplate via (8) T10 screws:
Photo 16
Once the gauge servo PCB assembly screws are removed both it and the odometer assembly can be removed from the faceplate:
Photo 17
A closer view of the odometer and the trip meter resetting action:
Photo 18
Left image shows trip meter engaged, right image showing the driving gear disengaged, allowing the counters to reset and register 000.0. The highlighted shaft supports gears that turn each counter one full revolution until its close to reading zero again. A pin located in the left side of each counter wheel will engage an inner rib of the adjacent counter wheel causing that counter to register one number higher.
During reset fingers also mounted to the highlighted shaft push against each counter so they freely revolve to a place they display 000.0. This is purely a mechanical action and counters are not spring loaded so they donít ďunwindĒ when the reset lever is pushed.
Its possible to complete disassemble the entire trip meter and odometer down to its individual parts. Iíve done it myself. Being honest though it was quite a task, mostly trial and error which eventually resulted in a working cluster once again. The only item that would fail is the DC stepper motor, somewhat easily replaced as shown below. Replacing just the motor would allow you to maintain the present indicated mileage.
By gently lifting the tabs holding the motor to the odometer frame and twisting it counter-clockwise will release it.
Photo 19
Individual servos are soldered to the larger PCB, seem to be the same for water temp, oil pressure, fuel level and voltage. In theory it should be possible to desolder them from the PCB and replace with a known good servo.
Photo 20
This would be possible only if the cluster is disassembled as shown. (Iíve not tried this myself---it might be less trouble to simply find a guaranteed salvaged cluster, vehicle and model year specific.)
More details:
Showing the servo shaft, a pointer and range limit stops of the faceplate opening:
Photo 21
Iím not sure the exact reason for these features but may edit this if it becomes known to me at a later date.
So this is inside a working cluster and now shouldnít be a mystery or unknown part of our vehicles. An upcoming project will have me modifying a 97-98 F-Series/Expedition cluster with factory tach to be used in my own Ď00 E250 van. Look for it sometime soon and thanks for reading!
Old 04-23-2012, 06:30 PM
Tom's Avatar
Tom Tom is offline
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
Really great stuff here, J W, thanks for taking the time to put this together for us!
Old 02-05-2014, 11:16 PM
OSHS OSHS is offline
OSHS is starting off with a positive reputation.
Interesting, JWA. I purchased a cheap F-250/350 cluster years ago and plugged it up in place of my E-350's cluster. Everything except for the tach worked. The F-series (Super Duty) plugged right up, but again, the tachometer did not work.
At that point, I lost interest in the project. It's been years since I have tinkered with the mod, but if needed, I can go dig up that old SD cluster in the basement.
-Brandon
01 E-350 15-Passenger 20valve
Old 02-06-2014, 06:12 AM
JWA's Avatar
JWA JWA is offline
Thanks Brandon----I'm almost in the same place as you, at least mentally.
I'm bound and determined to adapt an F-Series cluster w/tach into an E-Series. More than a few clusters collected for the project but I'm somewhat stuck (or unmotivated so far) to determine if the cluster or the chassis wiring needs modification in order for the swap to yield a properly working cluster.
One day------I swear!
Old 02-07-2014, 08:47 AM
Rick1025 Rick1025 is offline
Rick1025 is starting off with a positive reputation.
Just a question. Why is everyone trying to adapt an "F" series cluster and not a newer "E" series cluster that has a tach?
Old 02-07-2014, 09:10 AM
katoranger katoranger is offline
katoranger is starting off with a positive reputation.
This is interesting. I would like a tach too. Thinking for now that a scangauge or ultragauge will be used.
Rick, I think that the newer clusters have the digital odometer. Also I am not sure if the e-series prior to redesigned dash had a tach as an option.
Far from knowing much, but that is what I have gathered.
Old 02-07-2014, 11:34 AM
I *think* the tachometer in/on the cluster was put in around the same time of the minor grille change, which was 2004?? The interior was basically unchanged until 2009, when it was thoroughly updated. The 2008 had the new front end, but kept the old interior/dash for one year.
While I haven't done nearly as much work as JWA has on this (installing a factory tachometer), my quick experiments lead me to believe that it may be that the wiring in the dash doesn't have provisions for a tachometer. Or, at least it won't be plug-n-play.
Old 02-07-2014, 02:00 PM
If the earlier 98-04? vans never had a factory tach the wiring is probably not present. I guess I did not notice the grille change of 04. Will need to look into that. Thoughts of future updates.
Old 02-08-2014, 06:31 AM
JWA's Avatar
JWA JWA is offline
Quote:
Mostly because the E-Series chassis wiring won't accommodate the newer clusters. Without delving too deeply into this clusters are a vital link in the whole power train function and control, highly dependent on model, year and engine.
The clusters with tach have digital trip & odometer display which would most likely greatly impact the wiring connections. Additionally IF the digital trip/odo could be integrated AND you'd want the saved in memory mileage to be properly displayed its a costly service performed by a very few cluster repair facilities.
Short answer might be because they're not plug 'n play---or drive in this instance?
For the same approximate year an F-Series cluster makes sense because they're similar enough re-wiring them or the chassis is "easier" however that's a highly subjective term for this project!
FWIW '08 received the new front sheet metal, 2009 received the newer dash boards.
Old 09-29-2015, 07:53 AM
79schaefer's Avatar
79schaefer 79schaefer is offline
79schaefer is starting off with a positive reputation.
There is some minor rewiring required for the Superduty cluster to work in the E series. It is not that bad, if you have the wiring diagrams for both. The van I am working on right now, I have converted it to the Superduty cluster, before switching to the 2010 cluster. Reason for doing this, the tach function, and to get the 4x4 and 4low lights in the dash.
Steve S.
To many to list.
E Van Door Panel Removal JWA Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 7 02-21-2017 10:08 AM
Door Panel Removal JWA 1968-2013 Full Size Vans 21 05-20-2016 05:17 AM
UPDATED! E-Van Disease and POR-15 JWA Paint & Bodywork 11 06-08-2015 08:29 PM
Windshield Washer Reservoir R&I JWA 1968-2013 Full Size Vans 2 06-02-2013 05:31 AM
Cluster JWA User Gallery & Picture Display 0 04-23-2012 02:44 PM
Tags
268, 73l, anatomy, ford, gears, gether, motor, putting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
