1966 Ford F250 4x4 Horn Debacle
No, I'm not a Texas Aggie! Lol. I'm from Pennsyltucky and have never even been to Texas
Basically what you are saying is that the ground is just floating as if the wire were disconnected while the positive is always connected. Then when the button is pushed, it grounds the wire to the steering wheel/column.
I think I have come up with a temporary solution to the problem. There is a brush that was added to the T/S switch (you can see it in the picture). It constantly rubs the bottom of the hub, which has a copper ring all around the bottom of it. There was a wire soldered to the copper ring. If I solder another wire to the ring on the hub and run it up to the metal ring on the underside of the floating horn button (which has a little connector for a wire), it should work. When the horn button is pressed, the metal ring will make contact with the steering wheel, create the ground and sound the horn.
I will pick up some wire sometime this week and wire it up. I'll let you guys know how it goes. Still, it will be much better to have the correct wheel. The truck is a pain in the butt to steer because the gypo wheel is too small and I like things to be done the right way.
Thanks for all of your help!
The tapered spring placed in the aftermarket horn button (not shown) holds the insulator plate away from grounding on the aftermarket wheel until the horn button is depressed.
To dacampeau:
Eureka, you have got it exactly! You can see how your description fits (except the hub you described with the copper contacting plate is not shown here.)
BTW, If you have manual steering those small aftermarket wheels are a pain. Original size is 17" IIRC vs maybe 13" on an aftermarket wheel, so you have a big mechanical advantage with an original wheel. Down size is: they sell for about $200 in repro form. Then you also need several other parts to make the horn blow.
Thanks!
Applications: 1960/63 Falcon/Comet / 1961/66 F100/250 2WD / 1966 F100 4WD / 1966/73 Bronco / 1967/70 F100/250 2WD/4WD / 1969/70 F350.
C1TZ-3600-A Black & C1TZ-3600-B White .. 18" 4 spoke Steering Wheels / Obsolete / Not reproduced / No Ford Dealer or obsolete parts vendor has any.
Applications: 1961/65 F100/250 4WD / 1961/66 F350 / 1966 F250 4WD.
Lemme know if you still want me to drive to South Central LA to see if Tthetruck junkyard still has some 4 spoke 18" steering wheels.
Thanks so much.
Ill take a look at the wiring setup on these trucks to make sure how to advise on how to proceed to bypass the horn button if thats what you are trying to do. Best guess without looking at a wiring diagram is that you will have to ad a button or contact someplace other than the steering wheel or column and it sounds like you dont want to do that. Like Bill says with some type of aftermarket steering wheel you may be SOL. Let me take a look at the wiring diagram and get back to you. It may take a day or two but you will hear back from me. Hey Bill any chance that South Central would have any of the repair panels for the bottom of the tailight housings on the wrong long styleside boxes? Just curious as they seem to have alot of useful stuff there and these are not reproduced anywhere. Would they mind if you gave out the phone # so someone not from the area could call and check for certain parts. I talked to a few people at Portland that were reluctant to have their phone # out on the internet. These guys might be the same way if so I understand.
It was in this post I carried it forward for you. I didnt think about that at the time we spoke on the phone. So I was just interested in what they may have available down there. I know the body parts Im looking for are not repoped but I wondered if they were ever made as a body shop repair panel and mybe Ford supplied them at one time as a body panel repair part. Hey if you never ask you never get an answer.
Hope this quick reply on an old thread works, Bill. I'm new to the site.
I am trying to fix my '66 F250 4WD TSS and horn issue. Based on other posts, I found and purchased a NOS TSS for the truck, and got my brake lights and blinkers working. Now I need a steering wheel (and brush, and...) that accommodates the stock brush / button system (Rather than the Grant POS on there now) If you have a line on an original 4 spoke - that would be great.
I'm stumped by some of your info on the 3 spoke - do you think a standard repro will fit and work on my F250? It looks like the same horn system.
BTW, the truck has power steering, so I don't need the leverage of a larger wheel - but I may need to work on the shaft to make it all fit (It has the end nub extension that likely needs to be removed, at least)
Thanks so much for any help, and for all your posts on this site - I truly appreciate the greatness!
Thanks Christmas. I was not aware of the 2 brushes. I've heard about it, but didn't think that applied to my truck, as I have not seen it in any of the parts diagrams.
Do you know, are two brushes required to make the circuit, or are they just redundant to make the button contact action better / more reliable at any angle. Based on the parts and wires I see, I don't see how two brushes changes anything in the electrical circuit.
My truck is pretty far from stock, so I don't have dreams of getting it there - actually don't really want an 18" wheel, as I don't know how my legs are going to fit under it, and truck now has power steering, so don't need the leverage. NTL, I like the idea of stock and would be happy to live with a 4-spoke.
All that said, what's your opinion on a 3 spoke F100 wheel being able to bolt up and close the horn circuit with one brush? Seems like it could do the job.
#29
These guys are used to the 2WD trucks that have two brushes - one in the steering wheel center hub and one in the turn signal switch. The 4WD trucks use the flat metal plate of the switch as the contact point so no second brush for them.
Making your current turn signal switch work with a 2WD horn or making a 2WD wheel work with your horn would both require something extra to make it happen.
#30
Thanks TA455HO. So I guess I find an elusive 4 spoke, or I'm into customization.
I'm envisioning buying a stock horn spring contact, drill through some aftermarket adapter plate, add a plastic sleeve, drill and tap a for a ring lug on the top of the steering shaft, (verify I have good contact through the rag joint), find an after market horn button with enough stroke to engage/disengage spring contact (probably the hardest part here), attach two-wire after market horn button between steering shaft and spring contact.
Thoughts?
Thoughts?
