Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 04-23-2012, 05:31 PM
Ed Bamba Ed Bamba is offline
Garage is empty, add now
Ed Bamba is starting off with a positive reputation.
DIY brake bleeder failure (for me)
So after putting one together to bleed my brakes, it came out as a big disappointment. Here is the link to the one I made The DIY $20 brake bleeder
What failed for me was the cap on the master cyclinder. As little as 15psi caused the fluid to leak from around the bottom of the cap. I used the correct rubber gasket for the cap, which doesn't provide enough of a seal.
Anyone ever use this setup with any success?
BTW the master cyclinder is a Motorcraft part, and the modified cap and seal are from "HELP". The MS and calipers are brand new, along with a new booster.
__________________
1991 F150 Supercab XLT Lariat, 302 CI, M5OD tranny. All-steel custom hood with 72 Torino Grand Sport hood scoop, Night Stalker bumper cover. 92-96 side view mirrors.
  #2 (permalink)
Old 04-23-2012, 07:21 PM
Intimnasc's Avatar
Intimnasc Intimnasc is offline
2003 Jeep Wrangler
My Garage
Intimnasc is gaining momentum as a positive member of FTE.
I just took a low pressure regulator and made my own. Hooks to my compressor and I can totally flush my entire system in 15 minutes. As far as pressure bleeding I would not put more than 10 psi on the master cylinder anyways.
  #3 (permalink)
Old 04-23-2012, 07:42 PM
So you just used low pressure air to pressurize the reservoir? No brake fluid? If so, I guess I can just hook up my DIY bleeder, minus the brake fluid, pressurize it to 10 psi and try bleeding the system. Hopefully there will be enough volume in the pressure vessel to compensate for the leak around the cap. I only have one of those small compressors that doesn't put out much cfm.
__________________
  #4 (permalink)
Old 04-23-2012, 08:07 PM
pacrewchief pacrewchief is offline
pacrewchief is starting off with a positive reputation.
Brake Bleeder
15psi, way too much pressure. It will only take a pound or two to push the fluid through the truck.
  #5 (permalink)
Old 04-23-2012, 08:31 PM
I'll try less pressure and see what happens.
__________________
  #6 (permalink)
Old 04-24-2012, 02:04 AM
metriccar metriccar is offline
metriccar is starting off with a positive reputation.
I've just used the one man brake bleeder kits with no problem? Or are you talking about flushing?
  #7 (permalink)
Old 04-24-2012, 07:00 AM
Not sure if we're talking about the same thing, but the device I'm using applies fluid, under low pressure, to the master cyclinder via a modified cap. What happened is that the modified cap and rubber gasket I am using did not adequately provide enough of a seal to keep the fluid from leaking from around the cap.
The device allows for one person to either bleed or flush the system. There should be enough fluid in the pressure vessel (garden sprayer) to keep the master cyclinder reservior from running out of fluid.
__________________
  #8 (permalink)
Old 04-24-2012, 07:26 AM
whiteboyslo's Avatar
whiteboyslo whiteboyslo is offline
1991 Ford F-250
whiteboyslo is starting off with a positive reputation.
I know Harbor Freight isn't the greatest stuff, but I have one of these and have used it several times with no complaints:
Brake Fluid Bleeder
This is the kind that hooks to your compressor. I don't use the auxiliary bottle for the reservoir because it's too much of a PITA. Instead, I stop and check the master every little bit (or have someone else check it for me if possible).
So far, I've used that to completely flush the brakes on my truck AND on a motorcycle. Worked great! The only problem I had was was that it can suck fluid out so fast that I had to be real careful not to empty the reservoir on the bike.
Mike
__________________
Ol' Blue - 1991 F-250 XLT Lariat Supercab Longbed 2WD IDI w/ Banks Sidewinder. ZF5. 3.55s. 70K original miles!
Looking for a set of bricknose captain's chairs and center console, blue preferred, driving distance from SoCal. If you know of any, please let me know.
  #9 (permalink)
Old 04-24-2012, 04:20 PM
Intimnasc's Avatar
2003 Jeep Wrangler
My Garage
Here is the pressure bleeder that I built out of crap I had laying around. I bought the QD fittings at a plumbing supply and the master cylinder caps.
First is the entire setup with the Ford cap setting to the side and the 04 Z71 and 04 Impala cap attached to the bleeder.
Click the image to open in full size.
Next is a closeup of the low pressure regulator and fittings.
And here is a closeup of the cap that fits my 94 F150 so you can see the QD fitting. I just drilled and tapped the cap then epoxied the fitting into the cap. On the underside you need to cut the rubber slightly to allow the air to flow.
  #10 (permalink)
Old 04-24-2012, 07:42 PM
Intimnasc, so you don't have the problem of air leaking out from under the cap like I do? Or is it not an issue with your setup since it appears you are using shop air to pressurize the MC?
I think that my setup should work if I can get the cap to seal properly. If not, I may just use the bleeder as a pressure device, without fluid, and bleed it that way.
Still looking for suggestions on some type of cap sealing material or options. If not, I'll guess I'll just have to figure it out. BTDT, but no sense reinventing the wheel if someone will share their ideas
__________________
Tags
bleader, bleeder, brake, cap, cylider, cylinder, diy, f150, ford, homemade, making, man, master, pressure
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
