Won't start after new Distributor install? - Ford Truck Enthusiasts Forums
Old 04-23-2012, 04:25 PM
JYP_66F100 JYP_66F100 is offline
JYP_66F100 is starting off with a positive reputation.
Angry Won't start after new Distributor install?
<style type="text/css"> <!-- @page { margin: 0.79in } P { margin-bottom: 0.08in } --> </style> Bare with me fellows I am new to the Forum and to this site.
I have been a Ford fan for years I grew up learning to drive in a 61 uni-body pickup.
I have a 1966 Ford F100 with 352 5.8L V8, with four on the floor.
I recently installed a Pertronix Distributor with a Flamthrower Coil and a new 1.6 ohm Ballast Resister. The reason I replaced the original Distributor was because of a cracked housing, on the distributor, which I have never seen before, yet there is was. Since I did that I figured I would replace the coil. I followed the instructions to the tee, yet I am having trouble starting. I acts like it is not getting enough “spark”? I have an Edelbrock ASV 750 Carb on it and it is getting plenty of Fuel.
It sputters and coughs, Yet it won't fire/start!
Any suggestions would be appreciated.
JYP
Old 04-23-2012, 04:51 PM
Mikulh Mikulh is online now
Mikulh is gaining momentum as a positive member of FTE.Mikulh is gaining momentum as a positive member of FTE.
I have a couple of thoughts...
1. I don't think the flamethrower coils require a ballast resistor...the one I installed in my '67 mustang didn't. I don't think adding one would cause the problem you're describing, but it may not be helping the situation.
2. Do you think you might have installed the distributor off by a tooth?... it's easy to do.
Old 04-23-2012, 08:41 PM
garbz2's Avatar
garbz2 garbz2 is offline
garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.
Start over and make sure the engine is in time.
Number one TDC on the compression stroke.
Pull the valve cover and make sure.
Sounds like you are a tooth or two off on the timing.
Garbz
Old 04-23-2012, 10:04 PM
birdhaus's Avatar
birdhaus birdhaus is offline
birdhaus is starting off with a positive reputation.
I have the same distributor / coil on my 352, recently installed, I did have to find top dead center, pulled #1 plug and bumped it until the paper towel plug I made flew out...
Makes a lot of spark.. you can gap your spark plugs wider too...
Old 04-23-2012, 11:10 PM
tbm3fan's Avatar
tbm3fan tbm3fan is offline
tbm3fan is a splendid one to beholdtbm3fan is a splendid one to beholdtbm3fan is a splendid one to beholdtbm3fan is a splendid one to beholdtbm3fan is a splendid one to beholdtbm3fan is a splendid one to beholdtbm3fan is a splendid one to behold
Wait a second. I assume you used one of their Billet distributors which is to be used with a Flamethrower II coil of 0.6 ohms of resistance. That is the internal resistance of their coil unlike our standard Ford coils which need external resistance.
So I am going to make an assumption here. You have a 1.6 ohm ballast resistor on top of their 0.6 ohm internally resistance coil. A further wild guess deals with the stock Ford pink wire which is adding more resistance from switch to coil. Lots of resistance from what I am guessing on the info you supplied. I would then bet you are nowhere close to 11v at the coil when the ignition is in the start position. You are probably under 9v at the coil (+) which means the engine will never start.
So run a jumper wire from battery to the red ignitor wire and start. A volt meter can verify your voltage as I have gotten real good at doing that on a Mopar engine switching out one electronic system for another. If this test works then dump the ballast resistor (mandatory) and bypass the pink wire which is easy and get 12v to (+) coil terminal.
Old 04-24-2012, 11:16 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
ALL 1960/72 FoMoCo vehicles already have a resistor, this:
COLF-12250-A .. Resistor Wire-Ignition Coil (Motorcraft DY-37)
61.49" long / Color coded pink / 1.30-1.40 ohms resistance / #20 gauge wire.
Why would it be necessary to install a ballast resistor since the truck already has this resistor wire?
Old 04-24-2012, 10:17 PM
OldHarley's Avatar
OldHarley OldHarley is offline
OldHarley has a good reputation on FTE.OldHarley has a good reputation on FTE.OldHarley has a good reputation on FTE.
Quote:
Originally Posted by tbm3fan View Post
So I am going to make an assumption here. You have a 1.6 ohm ballast resistor on top of their 0.6 ohm internally resistance coil. A further wild guess deals with the stock Ford pink wire which is adding more resistance from switch to coil I am afraid, Grasshopper, that you are forgetting the resistance wire does not come into play during starting since a full 12v is delivered to the coil from the "I" solenoid terminal during starting.Lots of resistance from what I am guessing on the info you supplied. I would then bet you are nowhere close to 11v at the coil when the ignition is in the start position. You are probably under 9v at the coil (+) which means the engine will never start.
I like garbz2/mikulh's 'off by a tooth' answer, better.
Old 04-25-2012, 01:31 AM
tbm3fan's Avatar
You're right, my bad just wasn't thinking clearly. However with the ballast resistor in place anything is now possible. Combine this with the fact that no coil gets 12V during start even with the resistor wire bypassed. Did too much voltage testing in order to learn that. Between resistance in the start wire and old wiring you might get only 9V in start from some cars. The ballast resistor could easily drop him under 9V since my Mopar, with ballast resistor, only saw 9V at start. Bypassing that resistor and I get 11V at start. Easier to test this first before pulling off a water pump and timing cover.
Old 04-25-2012, 09:37 AM
gfw1985's Avatar
gfw1985 gfw1985 is offline
Cranky Old Guy
gfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to all
If the new ballast resistor was installed right before the coil, then yes that would reduce voltage in start position. Being off a tooth, 180* out, firing order incorrect still are all good possibilities. Do not understand reasoning behind pulling timing cover and water pump.
Old 04-25-2012, 10:05 PM
tbm3fan's Avatar
I was reading garbz2 and wasn't paying attention to his off a tooth remark. He was talking distributor and I was thinking timing chain. How I came up with that is the bigger mystery...
Old 04-27-2012, 02:52 PM
Thanks Gentlemen, I will endeavor to check all possibilities this weekend. Much appreciated.
1940 Ford Pickup 1/2 Ton Specs Alanok 1947 and Older Ford Trucks 21 06-30-2016 05:51 AM
SCT 5015 Programmer and PLX EGT Probe Issue... jaybread Computer Chips & Tuners 0 03-10-2014 10:13 AM
Ford Dump Truck 1942-47 - What year Biggoomba 1947 and Older Ford Trucks 41 11-27-2013 07:07 PM
3G conversion DeeV8er 1967 - 1972 F-100 & Larger F-Series Trucks 10 10-27-2013 07:25 AM
Camshaft???? RANGER589 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 18 06-03-2011 10:03 AM
Tags
260, 352, 68, car, crank, distribuitor, distributor, ford, install, installed, mustang, put, set, start, tooth, truck, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
