6.7 high miles - Ford Truck Enthusiasts Forums
6.7 high miles
Old 04-23-2012, 02:35 PM
tolliewolly's Avatar
tolliewolly tolliewolly is offline
tolliewolly is gaining momentum as a positive member of FTE.tolliewolly is gaining momentum as a positive member of FTE.
6.7 high miles
I was wondering how theses motors are holding up. I am hoping they will last to a million miles but I am not sure since the motor is new.
So lets see then........
All of the people that have alot of miles on their 6.7 diesel, chime in and lets hear how many miles you have so far. Also if any issues.
Old 04-23-2012, 02:40 PM
SavageNFS's Avatar
SavageNFS SavageNFS is online now
not a WHITE truck
SavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputation
just turned 35k on mine...no issues
I am not the original owner, but it has only been seen for normal maintenance according to my local Ford garage.
Old 04-23-2012, 03:05 PM
grampscamper grampscamper is online now
grampscamper has a good reputation on FTE.grampscamper has a good reputation on FTE.
Mine has 23,000 miles. It's a 2011 and just developed an oil leak. Dealer said they will need it for 2-3 days to diagnose & repair. Oil is on and around the oil pan but is leaking from somewhere above. Mechanic will need some time to investigate. Not feeling good about my purchase now. I was worried about a first year build. I also had trouble once when it would not crank over. It took three attempts than started. No trouble starting lately. Mine was an early 2010 build.<O</O
Old 04-23-2012, 07:01 PM
buckmasters's Avatar
buckmasters buckmasters is offline
buckmasters is starting off with a positive reputation.
22,000 miles here and no issues whatsoever. The only concern I have is the life of the engine coolant. The manual states it is good for over 100,000 miles, but when I had mine checked at 15,000 miles it required additive. From what I understand, you can only do this twice before having to replace all the fluid.
In general, these kinds of threads are a love/hate for me. I either hear about people like me with no issues and feel great about my purchase or hear about those with engine failure, death wobble, and HPFP replacements causing me to cross my fingers every time I put the key in the ignition.
Old 04-23-2012, 09:12 PM
ruschejj's Avatar
ruschejj ruschejj is offline
ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.
Mine has a little over 98,000 on it. Will break 100,000 by the end of the month.
I needed a new radiator at 52,000 miles. I still have not done the latest flash and NOx calibration. I'm afraid to fix something that's not broken.
I absolutely love the engine and the truck. Everything has been rock solid except the radiator.
Next month I plan on changing out the trans fluid, flushing cooling systems, rotating the tires, checking the brakes real good (probably will remove the calipers and lube the pad races).
I also need to clean my AFE air filter. I've got an AFE DPF back exhaust pipe on the way I will install as well as some husky mudflaps.
So, those of you that have had nagging little issues that cause you to be worried about a young drivetrain, I'm not having that experience. My truck is perfect for me except I wish I had the 11,500 GVWR sticker.....
Old 04-23-2012, 09:37 PM
FONRDAY's Avatar
FONRDAY FONRDAY is offline
FONRDAY is starting off with a positive reputation.
my company has one 126,000 only one water pump and fan clutch and a nox sensor and it gets beaten seven days a week a sixteen hour shift its a early build one first hundred i was told
Old 04-24-2012, 12:36 AM
green 69's Avatar
green 69 green 69 is offline
green 69 is starting off with a positive reputation.
Hey ruschej,
not to get off topic or hijack this post but do you have pics of your sub box
Old 04-24-2012, 06:31 AM
98 and 126! Now that's some miles. Good to hear they are doing well
Old 04-24-2012, 08:15 AM
jrc1978 jrc1978 is offline
jrc1978 is starting off with a positive reputation.
1,500 miles and counting with no issues whatsoever!
Sorry, thought that would make an interesting first post on the forum
Old 04-24-2012, 08:42 AM
sdetweil's Avatar
sdetweil sdetweil is offline
sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.
welcome!.. update your profile with your location.. might be near some of us!..
and of course, you have to post pics.
Mine just crossed 1000miles..
Sam
Old 04-24-2012, 09:08 AM
OldGreaser OldGreaser is offline
OldGreaser is starting off with a positive reputation.
Only 31k miles so far. about 3/4 of this has been towing an 18k 5th wheel. I hope to get 10 times this.
Old 04-24-2012, 02:48 PM
Sam
Updated my location. For some reason, I don't have signature access. I'm not seeing it as an option in the User CP. Not sure if it's a noob thing or what. Here's a pic of my '11. I traded in an 05 Cummins for it. So far, so good. Got a long way to go before I really trust it, though. Just my nature. Any thread about high mileage 6.7s always get my attention. I'm interested to know how everyone's truck is holding up. I was leery about trading in a proven truck on the unproven 6.7.
BTW, that '55 is sick. A buddy of mine has a '68 that he's in the process of hot rodding with a small block and a 5sp Tremec. I love the old truck style.
Old 04-24-2012, 02:52 PM
sdetweil's Avatar
FTE puts some limits on user function to prevent bots from autoposting junk..
you have to have 25 posts before avatar, signature and instant message functions appear
Old 04-24-2012, 02:53 PM
Sweet. Thanks for the heads up.
Old 04-24-2012, 02:54 PM
sdetweil's Avatar
thanks.. the pics don't do it justice.. the green is a green candy over a green metallic.. and clear over all that.. really glitters in the sun..
hoping to get my 56 F100 Big window on the road soon..
sam
Drive to clean DPF nathan_2017 2017 Super Duty 8 12-24-2016 09:23 AM
Soon to be 6.7 owner sudsmcduff 6.7L Power Stroke Diesel 17 04-28-2016 11:24 AM
How does 6.7 compare with 6.0? ugh3012 1999 to 2016 Super Duty 14 06-16-2015 08:59 PM
New Owner With Questions... PDoyle 6.7L Power Stroke Diesel 13 03-30-2014 03:02 PM
6.7 l lDIESEL REPUTATION artfuldodger 1999 to 2016 Super Duty 4 12-02-2012 08:34 AM
Tags
100000, 18, 2011, 35, 67, f250, f350, ford, high, mileage, miles, powerstroke, tires, tow, vehicle, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
