You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I have a 2003 F150 Harley Davidson Edition truck and i was wanting some advice on upgrades for it. I no i want a cold air intake, exhaust, and headers just don't no what is good and what is not and any other advice on the truck itself. Thanks for any help
Hello, I am new to the ford supercharger world but have been around turbo diesel for sometime and have built some very fast trucks. I too am in the market to buy an 02 HD with 64000 miles on it and from what I have researched and been told by some of the great superchargers guys is this.
For a reliable daily driver a 6lb lower, ngk trg plugs gapped to .036, approphiate belt length, maf extender and the most important thing, the right custom tune from the right tuner.
headers are not needed for a daily driver, just when you want very high HP.
THOSE ARE MY PLANS..... I am sure somebody will add to it or dispute my post, but either way it has been proven. Look at a troyer stage 2 Kjit as well. good luck and I hope to own one soon.
PP&T (Pulley, Plugs and Tune) is a great place to start. 6lb lower for a DD
CAI is not needed until you have greater than 400hp but it looks nice.
Exhaust is good for a nice note. Headers are not needed.
Vac/Boost and A/F gauges are highly recommended.
MAF may be needed or may not be required.
Once completed there are a few NEW RULES for the fun peddle!
These NEW RULES keep you from joining the VBC (Vented Block Club)
One mod folks like is the FTVB (Factory Tech Valve Body).
(street version) OE 4x4 Pan and a new filter
How many miles are on the truck?
Has the intercooler been pulled and cleaned?
A good time to do this is when changing to colder plugs.
While the I/C is off is a good time to fill the silencer holes.
Did I mention installing Coil Pack Screws before you reassemble
IMHO the most important and first mod you should do is the L&S Oil Separator.
Enjoy!
ok the mileage is 23k and what is the dd stand for (6lb lower for a DD) and the silencer holes what is that sorry new to all this and thanks for the help just wondering y no on the headers just not worth the money
My thoughts on filling the silencer holes...It can be a problem.
I'm not a big fan of pouring JB weld in my S/C. Possible later problems.
If it's not done "just right" it can sag when curing and hit the blades.
If it sags when curing, you must remove the blades and file the excess.
It does nothing for performance & I like to be a bit more quiet and stealth.
If it's not done "just right" it can sag when curing and hit the blades. If it sags when curing, you must remove the blades and file the excess.
It's actually pretty easy to get it right. The tape easily holds the JB Weld until it cures, plus the blades really aren't close enough to the silencer holes to be a problem even if it wasn't perfect.
You can see from the pic above the blades have already curved away from the silencer holes creating tons of clearance.
That's why I never did it to mine. I've done it to a buddy's Eaton, but he wanted that louder whine.
Stewart
__________________ The Brotherhood of FTE <-click the link 1999 F150 Lightning: WMS built block, 6lb lower, Monsterbox, Truetrac, CF driveshaft 1999 PSD F250 SC 4x4: 38R, Stage 2's, T-500, JW trans, Live Tuned, lotsa Riffraff stuff 2000 PSD Excursion 4x4: 38R, JW trans, F5, MBRP, AFE, OBA and Pre-Pump, V & B codes Never Fry Bacon NAKED!
Filling the silencer holes...hahahahahahahaha
What, are you guys 16 years old? lol
And Ill go ahead and be different on the headers too.
I picked up 30 HP with long tube headers and high flow cats and that was when I was still making pretty low HP.
__________________
( Phil )2003 SuperCrew: JLP Built Lightning block/Stage 3 heads and cams.
L-conversion/Kenne Bell upgrade blower at 16PSI/BTS,4R100 tranny/100 shot nitrous.
594HP/620TQ Without the Nitrous 1.68 60' time/11.76 @ 116.17 with the 100 shot.
Join the the Delaware Chapter, HERE
thanks for all the help and for the pulley any good names, and recommendation on good oil just wondering since it is s/c or is mobile 1 or royal purple ok. and last thing how do i find a good tune place just google i guess
Slick, i'm sorry man, I'm not trying to be an azz, but I can't understand what you're asking. Is it possible you can add some punctuation to make it easier to understand?
Stewart
