Truck stalls when in forward gears.
So i got the shocks and exhaust done. went to take it for a first test run since i got it. went up my drive way and it started shaking really bad and sounding like it was going to stall. I bleed the fuel lines before hand because it had no fuel in it, also did the fuel filter prior to that. Got about 30 feet from where it started shaking and it stalled in drive. restarted it put it in 2nd, it stalled, put it in first and it shook bad, got it back into the drive way. Reverse seems to work fine, but the 3 forward gears make it want to stall and i dont know why. Its a 86 C6 6.9l by the way. any ideas fellas.
Something might be sticking in the valve body, it may be trying to engage the forward clutch and the low reverse clutch at the same time.
There is a vacuum modulator on the rightside of the trans it has a vacuum line going to it, pull the line and see if there is trans fluid in it, if it is replace the modulator.
And if it just had exhaust work the line may have accidently gotten pulled off.
How long did you run it after bleeding the system?
Sounds like possibly the clutches are toast and seized the drum(s). Here's a link to where I got all my parts, and they are very knowledgable. C4 C6 Performance Transmission from PATC, C6 Transmission
