Advice on replacing cab corners
My cab corners are rotted out and I'm looking to replace them. I got the corners already from a local source and looking to order inner corners and rear lower door pillar corners from RockAuto (which are Sherman parts). I looking for advice on what I'm getting into. It appears to be a matter of drilling out the spot welds, cutting out the old parts and welding in the new ones. I never did this type of body work so any advice for a rookie would be appreciated.
I would also use a cutoff wheel, because i got three of em, but no nibbler. im also not too hung up on the best looks either. I want it to look good, but not factory is fine for my ole girl... anyway, i would guess you will be welding the new panels in place... Just remember to spred the heat around.... meaning to use lots of patience and short welds to keep it from warping the metal....
Aaron-71
16
07-07-2010 10:59 PM
Pokey11
11-02-2008 03:16 PM
rcav8or
21
07-14-2008 07:40 PM
