4.2 swap into an antique - Ford Truck Enthusiasts Forums
Old 04-22-2012, 03:10 PM
lwclark's Avatar
lwclark lwclark is offline
lwclark is starting off with a positive reputation.
I have a '60 F100 and I'm replacing the 223 I6 with another one soon.
Someday when this "new" one wears out, I'd like to put a 4.2/5-speed into it, but I'm concerned about the PATS. I realize I need to bring over the engine wiring harness and computer, but will I need to graft in an F150 gauge cluster and ignition key assembly for the computer to let the engine run?
Thanks for any insight.
Larry
Old 04-22-2012, 10:26 PM
critterf1's Avatar
critterf1 critterf1 is offline
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
Certainly will.
Old 05-03-2012, 09:29 AM
Kruse Kruse is offline
Kruse is gaining momentum as a positive member of FTE.
After doing a complete 3.8 rebuild within the last few months on a '95 Mustang, I'd seriously consider a different engine for this swap. Many parts for the Ford V6 have been discontinued by Ford and are many times higher than a small block Chevy or a Windsor Ford.
Here is one example: F4SZ-6019-DA is a timing chain cover for the V6. I see one on ebay for $335. A timing chain cover for a Windsor Ford is $65-$130 at Summit.
This is just one example and I have a couple dozen more. I had to search the internet for lots of pieces that Ford should still stock, but they don't. Had I know that, I would have taken a different path.
Old 05-03-2012, 09:58 AM
lwclark's Avatar
Thanks. Good advice.
ecm computer problem scoobydum Computer Chips & Tuners 3 06-10-2012 08:59 AM
1991 F-150 Auto Trans, computer controlled? Hillcapper Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 10 01-20-2009 08:13 AM
94 351W Computer Swap AZAV8 Engine Swaps 3 05-13-2007 05:25 AM
Which PCU for 88 F150? diharris 1987 - 1996 F150 & Larger F-Series Trucks 3 05-21-2006 05:12 PM
Need to rebuild eec computer mike L 1987 - 1996 F150 & Larger F-Series Trucks 14 10-23-2004 08:39 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
42, antique, austin, bio, buy, diesel, f100, ford, swap, truck, tx, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
