97 expy 4.6 p0304 code
hi everyone
got the 0304 code yesterday...changed the plug...switched the#4 injector with # 1 cylinder and still got the same code.....getting spark from coil...anybody got ideas on what to do next before I take it to the shop? BTW it has been missing when I started it in the mornings but cleared up after 2 or 3 minutes and was fine for the rest of the day. did that for about a week or so. Also the truck has 258000 on it./ last time I changed the plugs and wires at 192000 all OEM
Vic
Vic
hi everyone
Vic
Vic
Causes
A code P0304 may mean that one or more of the following has happened:
- Faulty spark plug or wire
- Faulty coil (pack)
- Faulty oxygen sensor(s)
- Faulty fuel injector
- Burned exhaust valve
- Faulty catalytic converter(s)
- Running out of fuel
- Poor compression
- Defective computer
BTW, have you swapped out the spark plug wire to see if that's the problem?
okay, changed the plugs and wires with oem and problem solved. While I had everything apart I also cleaned the MAF sensor, cleaned throttle body and checked all vacumm lines (found one slightly cracked). Put everything back together and it runs great. cost was 133.00 and 4 hours of my time but it was worth every bit of it.
natsoundup
1997-2006 Expedition & Navigator
07-01-2007 03:45 PM
