weather stripping residue/stains - Ford Truck Enthusiasts Forums
Old 04-22-2012, 08:16 AM
Ralph Ralph is offline
Ralph is starting off with a positive reputation.
So I just picked up my new 2012 F150 King Ranch the other day. After getting it home and doing some accessory work to it I noticed a White residue/water stains on the rubber weather stripping around all four door windows. At first thought it was soap run marks from the dealership cleaning it before delivery. I tried to get it off and nothing seems to work. It's even on the inside of the rubber when you open the doors. Looks like soap run marks from not rinsing the truck with water. Took it back to the Ford Dealership and they took photos and turned it into Ford. They are tellin me that Ford will not do anything about it on a warranty item. The Dealership is going to try again but I don't have a lot of faith in them at this point. Does anyone have any luck with contacting Ford direct on issues? I just can't believe that you should be expected to live with something like that on brand new truck!
Any or all help would be greatly apprecicated.
Old 04-22-2012, 09:39 PM
TIO HD TIO HD is offline
TIO HD is starting off with a positive reputation.
I just got mine too this past Tuesday, I had the truck washed second time and still there. The dealer also washed it before I picked it up and seems the soap dried from day 1 at the dealer. Hopefully with time it'll go away after some wear from the normal weather.
Old 04-23-2012, 01:50 PM
juneau76's Avatar
juneau76 juneau76 is offline
juneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud of
I have a similar thing on mine, but on the interior weatherstripping. Two years later and I'm just ignoring it.
Old 04-24-2012, 05:54 PM
FORD COASTIE's Avatar
FORD COASTIE FORD COASTIE is online now
FORD COASTIE has a great reputation on FTE.FORD COASTIE has a great reputation on FTE.FORD COASTIE has a great reputation on FTE.FORD COASTIE has a great reputation on FTE.FORD COASTIE has a great reputation on FTE.FORD COASTIE has a great reputation on FTE.
Ralph, my engine blew at 600 miles in my 2011 F-150, due to a faulty crankshaft, and had to be replaced. I contacted corporate after the dealership failed me, and first asked for a new truck. When they refused, I asked for a free 100,000 mile extended warranty, to which they also refused. Good luck in dealing with corporate. My experience was not good, but I hope yours turns out well.
Old 04-25-2012, 03:32 AM
meborder's Avatar
meborder meborder is online now
meborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant future
sounds like it might be glue residue/overspray.... hard to tell not being there.
but if it is residue from a contact cement, this stuff will take it off on a hurry:
Old 04-25-2012, 07:06 PM
Terry Vanpool Terry Vanpool is offline
Terry Vanpool is starting off with a positive reputation.
My 2012 Lariat had these same stains on the door seals. I think it is a lubricant used to facilitate installation, it does not appear to be adhesive. I was able to clean it off with "Mothers" Back to Black and some elbow grease.
Old 04-25-2012, 10:30 PM
Steelerz1's Avatar
Steelerz1 Steelerz1 is offline
Steelerz1 is starting off with a positive reputation.
My new one has it too....looks like a white residue...almost like when you get wax on the weatherstripping....
Old 04-29-2012, 11:35 PM
Steelerz1's Avatar
Used a product called Goof Off today which removed the stains from my weatherstripping as well as the white wax residue left on my wheel well trim when the truck was detailed for delivery. Stuff works great...give it a try.
Old 04-30-2012, 07:29 PM
rhodeisland rhodeisland is offline
rhodeisland is starting off with a positive reputation.
Be careful with this stuff,we use it to remove wet 3M caulking and I believe it contains toluene and will attact rubber and some paint topcoats.
DIY: How to Polish Aluminum Like a Mirror (VIDEO) ProStreetDriver Brakes, Steering, Suspension, Tires, & Wheels 0 01-03-2017 02:55 PM
cleaning those darn cloth seats calicojack 2004 - 2008 F150 20 01-06-2014 06:49 PM
My new Michelins are turning brown & Michelin knows it. ztruck Brakes, Steering, Suspension, Tires, & Wheels 1 07-13-2013 07:27 AM
Cutting (Sanding) and Buffing COMPLIT1107 Paint & Bodywork 2 05-02-2010 09:16 AM
Turtle Wax Ice Products (warning there is a bunch of pictures) DaMole 2004 - 2008 F150 15 07-16-2007 09:57 AM
Tags
150, 2012, car, marks, remove, residue, spots, strip, stripping, trim, water, weather, white
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
