D60 Swap for my 86 F250HD Cummins 12V - Page 4 - Ford Truck Enthusiasts Forums
  #46
Old 12-07-2013, 11:41 PM
63nova86F250 63nova86F250 is offline
63nova86F250 is starting off with a positive reputation.
Mike, just noticed you're out of Albany up the road. My donor crewcab came out of Albany. I threw my Dana 50 back under it and I'm getting some of the mechanical issues sorted out to flip it. Bought it simply for the Dana 60 on a "mechanic special" type thing and figured I could make a few bucks in the deal.
  #47
Old 12-08-2013, 08:14 AM
Franklin2's Avatar
Franklin2 Franklin2 is online now
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Quote:
Originally Posted by 63nova86F250 View Post
Well I definitely don't have a mall cruiser. Yes, I have redone the truck and I keep it nice, but it has to work.
<a href="http://s46.photobucket.com/albums/f115/BansheeBrian/?action=view&current=0279ae64dd37b277cbfb3559b6b07 9cd.jpg" target="_blank"><img src="http://i46.photobucket.com/albums/f115/BansheeBrian/0279ae64dd37b277cbfb3559b6b079cd.jpg" border="0" alt="Photobucket Pictures, Images and Photos" /></a>
But I hear people use their trucks just for commuting?
With that said I don't go flexing it around or crawling around. When I use 4 wheel drive I'm very easy on it and it's never "wheeled". The pic above is with a load on it and my 33's.
You have got air bags or a very heavy aftermarket springs on that truck. It should sag some by design with that much load on it. If your springs are doing this, you must get a very rough ride empty.
  #48
Old 12-08-2013, 08:34 AM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
VERY clean truck, but 35s are going to rub with no lift. There is no way around it
  #49
Old 12-08-2013, 09:06 AM
00Boss's Avatar
00Boss 00Boss is offline
00Boss is gaining momentum as a positive member of FTE.00Boss is gaining momentum as a positive member of FTE.
I dont know bout that Brad 37s only rubbed on mine when I turned and twisted, like pullin out of my drive.
  #50
Old 12-08-2013, 09:37 AM
Quote:
Originally Posted by 00Boss View Post
.37s only rubbed on mine when I turned and twisted, like pullin out of my drive.
Leaving your driveway(an everyday occurrence) and your tires rubbed. yeah that sounds fine to deal with
  #51
Old 12-08-2013, 10:35 AM
Quote:
Neither of those actually. In this picture it has sagged. Now, it was equipped from the factory with the heavy overloads, so it sags to those and more or less and doesn't go a lot further after that. With that said, yes, it does ride like a truck of yesterday. There is no comparison for sure; hop in any newer super duty and you'd think it was a Cadillac compared to mine. But, I will out haul any new F350 that doesn't have aftermarket help. Now because it rides like an actual truck, I don't really want to do any sort of add-a-leaf to the front to clear tires and make it ride like a wagon and rubbing under normal driving is a non-starter for me too. Alright, I've stirred the pot enough it seems.
  #52
Old 12-08-2013, 11:06 AM
Franklin2's Avatar
That's all I like to see in a reply. "Yes, 37's will fit but they rub on sharp turns coming out of my driveway". The guy who asked the question can decided if he wants to deal with that or not. But you are letting him know the whole story and what to expect.
  #53
Old 06-28-2014, 08:45 AM
dylansf23's Avatar
dylansf23 dylansf23 is offline
dylansf23 is gaining momentum as a positive member of FTE.
i had 36" military tires on my f250 and never rubbed, only while wheeling i might rub the black behind my fender and at full lock left, it would just nick the leaf spring.
  #54
Old 06-28-2014, 02:58 PM
Rogue_Wulff's Avatar
Rogue_Wulff Rogue_Wulff is offline
Rogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to behold
I read thru the entire thread on that other sight. From the looks of it, I should be able to easily mount the engine and trans without having to do a bunch of major mods, aside from fabbing the engine to frame brackets. A step that might not have even been needed, had the original engine mounts been left intact on my engine.
  #55
Old 06-28-2014, 03:07 PM
fellro86's Avatar
fellro86 fellro86 is offline
Iowa Benevolent Dictator
fellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud of
I didn't have any to much trouble with mine. Main thing I would do different is the actual motor mount setup. The later Dodge trucks use an eye bushing like suspensions to mount, while the one I took apart used a regular sandwich style mount. Apparently the Dodge has a flatter angle, as the mounts have settled. A substitute I used is actually body bushings to deal with that settling. The trans mount isn't that hard to deal with since Ford made a number of mounting locations. I didn't have to change anything about the firewall or rad support for the motor, I had to modify the rad support for the intercooler.
  #56
Old 06-28-2014, 10:37 PM
Quote:
They did in 92, but not 80. All transmissions in 80 had the same mount location, and the used the same mount/crossmember.
  #57
Old 06-29-2014, 08:58 AM
fellro86's Avatar
Well that will make it easier in a sense to locate it... not so easy if you want to keep using the end braces.
95 fummins not enoughsmoke Engine Swaps 104 02-13-2016 12:46 PM
My 1983 F-250 project. dazedandconfused 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 105 05-01-2015 03:46 PM
Howdie! New Ford truck owner here! Fall_of_Olympus New Member Introductions 3 11-26-2014 08:40 AM
Pics of the beast before I traded her in LONG EL 2007 - 2014 Expedition & Navigator 29 01-17-2012 12:55 PM
New pics up!!! please comment!!! GETDOWN!!! 1997 - 2003 F150 46 09-24-2009 12:43 AM
Tags
6bt, 85, 86, ac, conversion, cummins, d60, f150, f350, high, mount, needed, pump, shocks, swap, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
