Early '99 F350 front axle rebuild.
Hello all,
I'm rebuilding the front end on my Early '99 F350 4x4 Dually. Starting with the right side. My first question is this, I can get a good '04 axle shaft. Will it fit? (knuckle seal, etc.) After that, if I install an after 3/22/99 hub assembly, is my only requirement a 13mm rotor? Are the caliper & bracket interchangeable? Finally, are manual locking hubs really dually specific? The warn site claims they are, but I see quite a few guys saying standard hubs are fine w/ the dually spacer.
Any input is appreciated.
murrhee
11-11-2010 09:49 PM
