Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Southern Region > North Carolina Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
North Carolina Chapter Join Chapter, Leader:ncheavymetal
  #1 (permalink)
Old 04-21-2012, 08:32 AM
cpeters1965's Avatar
cpeters1965 cpeters1965 is offline
Garage is empty, add now
cpeters1965 is starting off with a positive reputation.
padrhaig
Need a second set of eyes please!
Morning all,
I need a little help and hoping someone nearby can help. My truck seems to have a leak I can't track and need a second set of eyes to track it (and tell me if its not serious). Live in Chapel Hill. As it's my only vehicle, I'm kinda in semi panic mode. Can be reached @ 919 408 7463. Hope desperately to hear thanks!
  #2 (permalink)
Old 04-21-2012, 12:26 PM
wp120470's Avatar
wp120470 wp120470 is offline
1967 Ford Falcon
wp120470 is a name known to allwp120470 is a name known to allwp120470 is a name known to allwp120470 is a name known to allwp120470 is a name known to allwp120470 is a name known to all
What year, Make, Model, Engine size truck do you have and what is it leaking sir?
  #3 (permalink)
Old 04-21-2012, 12:31 PM
padrhaig
97 explorer xlt, X-vin, RWD, AOD leak appears to be coming from front
  #4 (permalink)
Old 04-21-2012, 12:37 PM
wp120470's Avatar
1967 Ford Falcon
Ok. V6 Or V8? How Many Litres engine is it? do you know if its leaking coolant, oil, transmission fluid?
  #5 (permalink)
Old 04-21-2012, 12:38 PM
padrhaig
4.0 6 cylinder appears to be antifreeze
  #6 (permalink)
Old 04-21-2012, 12:44 PM
wp120470's Avatar
1967 Ford Falcon
Can you see the seep hole on top of the waterpump shaft on the front? If so is it wet?
  #7 (permalink)
Old 04-21-2012, 12:55 PM
padrhaig
No I can't not sure what I am looking for.
  #8 (permalink)
Old 04-21-2012, 01:12 PM
wp120470's Avatar
1967 Ford Falcon
Ok. On the front of your engine. Standing on the drivers side of the hood latch, look down at the belt drive system. the pulley right in the middle should be the water pump. Right behind the pulley is the front of the waterpump shaft. sometimes when the bearings go out, the seal fails and the hole, on the front top, of the waterpump shaft gets wet where the leak originates. it helps to use a bright flashlight.
  #9 (permalink)
Old 04-21-2012, 01:14 PM
padrhaig
just took a look again with the info you gave, it is dry
  #10 (permalink)
Old 04-21-2012, 01:44 PM
wp120470's Avatar
1967 Ford Falcon
Ok look at the bottom of the radiator see if it is wet. Maybe the seam on the side of the radiator is lwaking.
  #11 (permalink)
Old 04-21-2012, 06:15 PM
padrhaig
Right now everything is looking dry underneath.
  #12 (permalink)
Old 04-21-2012, 07:55 PM
wp120470's Avatar
1967 Ford Falcon
Have you checked the fluid levels of the engine? Oil?Tranny? Radiator? Power steering? Brake? We need to know to be able to help.
  #13 (permalink)
Old 04-22-2012, 05:13 AM
padrhaig
Yes I have all fluids look good and are up to level, no water in the oil
  #14 (permalink)
Old 04-23-2012, 05:42 AM
wp120470's Avatar
1967 Ford Falcon
Then I would say that is is not an emergency and you should have your local garage check it out as soon as possibile.
  #15 (permalink)
Old 04-23-2012, 07:16 AM
padrhaig
wp120470,
Thank you for all the assistance. I am the mechanic so is why was asking for a second set of eyes. Still asking for them. Drove to work today (16 miles) and checked it. Definately leaking, looks to be where you stated under the water pump, but want a second opinion with somebody looking with me before I proceed. Just had 15 yr old out of hospital so there is no spare cash available for garage rates :-(
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
