twisted the return fuel line on secondary fuel filter
we like the title says i twisted the return line on the filter housing while trying to do the blue spring install. my question is will that hurt me since it is a return or do i need to fix it. also where can you get a replacment line? local junk yard has no trucks to pull from.
Back-up wrenches are critical to use.
Return line from regulator year: 05, 06, 07
5C3Z-9C273-AA
Be sure to confirm this before ordering, but I am 90% sure that this is the part #.
No way to tell over the internet on how badly it is restricted.
I would probably change it if it were mine though.
5C3Z-9C273-AA
Remove the regulator housing with the return line still attached as I am sure the reason it got bent was due to the fact that the fitting wouldn't separate. Spin the regulator housing to remove it from the return line. Thread the new housing on the return by spinning it and then screwing it back to the bowl. After you have it tight, tighten the return line and the return line will straighten out. Mine did atleast with no leaks or spiked pressure readings.
MucksCo
04-23-2012 10:14 PM
