what transmission ?
#31
Been there, tried that, and Mark confirmed!
They are in deed very different bolt patterns.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
#32
#33
#36
#42
If Mark decides to chime back in I'm sure he can correct me.
But they are basically the same except the E4OD has overdrive.
The newer 4R100 used behind the diesels came with 6 pinion steel planets vs 3 or 4 pinion (I don't recall exactly) alum planets in the E4 and C6, so the 4R are even stronger.
__________________
#43
I'm to the point now that I keep asking question because Im wondering if a guy could gather enough parts to put a C6 behind a PSD in a rat rod. Before I start calling my ford dealer asking for parts I want to make sure what I'm asking for will be in the computer. You can get a C6 pretty cheap. If all I need is some special electronic vacuum regulator and a manual pcm to drop a C6 behind my PSD, that's sweet! I've got a KB-3 IH truck that needs a PSD, C6 and 3:08 gears......
#44
And, of course, the electronic control (thus the "E"). Dunno why people take these questions so personally, or go on about what they "believe". The relevant thing is the question of how it can be done. Our trucks have neither engine vacuum nor an injection pump. That doesn't mean it's impossible to run a C6 behind one. But it would have to have some electromechanical solenoid that would draw the pumped vacuum, and regulate it electronically based on load and/or speed, A sufficiently elaborate contraption, informed by PCM data, could do it. The PCM would also have to ignore the _inputs_ from the tranny (AFAIK, the C6 produces no electronic output like the E4OD).
And if we are gonna talk "belief", I honestly _don't_ doubt that Ford would come up with such a Rube Goldberg. They've never let a simpler solution get in the way of using a more complex one.
#45
Auto PCM will be fine if that's what you have. The PCM just sends signals out to shift, speed monitoring, etc and doesn't care if anything is on the other end of the wire or not.
__________________
