Camber specs for 2001 F250 2WD - Questions after lift kit install and alignment...
I installed the 2" lift blocks on my 2001 F250 2wd and rotated the camber bushings myself to get the wheels somewhat up/down and not leaning out/in so it would drive halfway decent when I brought it to get tires and an alignment.
I then had new tires and an alignment done and now the tops of the tires are leaning out ever so slightly. Is this "normal" or to spec?
Anybody know the spec for camber?
Come to think of it it looks like it did when I dropped it off. Looks like they didn't touch the camber at all but did align it. Shop says all is OK...
Anybody know what the "spec" is for camber? Are the tops supposed to lean out ever so slightly so that as the suspension goes up/down with the bumps in the road the tire stays near 0* throughout the swing? Make sense?
zero degrees is typical for a 4x4. Not sure exactly what it should be for your 2x4, BUT if you can notice the wheels showing positive camber, I can bet it is way too much. It is virtually impossible to "eyeball" an alignment. Did the shop give you a print out with the before and after? I have mi front end at I think -0.5 +/- camber, 0.0* toe in, and right caster is 4.0* I think and left is 3.0*. I don't recall the specs exactly but a cross caster of -.05* should be close. Keep in mind that most GOOD alignments will cost around $80+++. If you get a shop to do it for much cheaper than that, they most likely just set the toe in and that's it.
Just had mine aligned after putting 2" level lift on my 2wd.
Alignment shop installed new camber bushings that made the wheels sit level. The old stock bushings were unusable due to the lift. They showed me the ones they put in and my stock ones. Actually there was a big difference between the two!
I going through this issue as we speak. I have had my alignment done twice and cant get it the way it should be. Ref the clunk, I too have that issue and narrowed it down to my tie rod ends. Once I turn the wheel, at a certain point, the tie rod pops. Travel up and down. I am going to replace all tie rods ends and see what happens since I had already replaced the ball units.
If I was to guess, our 4x2 trucks aren't meant to be lifted. I think it throws off the i beam's and radius arms from their neutral position.
My current alignment, the wheels are close to straight up and down.
Here is a kit I helped a friend install a few years backs. lift kits
Personally I think it silly to be lifting a 2wd drive 4 or 6 inchs but to each their own. My friend did it just so he could put big tires on.
Now I would like to bring the front end of my 2wd F350 up to bring it just alittle short of level. So if and when I tow heavy it is level.
And for you guys looking for a good alignment shop. There are 2 important factors. 1: The tech doing the alignment. 2: Find a shop that has a Hunter alignment machine that is less than 5yrs old and ask how offen they actually calibate the machines. Most alignment shops are "Toe and Go" shops. And always tell them up front you want a print out. Sorry for going on but when I was a younger man alignments was something I took pride in doing.
Dutter
1983 - 2012 Ranger & B-Series
01-04-2014 02:06 AM
