Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1967 - 1972 F-100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1967 - 1972 F-100 & Larger F-Series Trucks Discuss the Bumpsides Ford Truck SPONSORED BY:
  #1 (permalink)
Old 04-20-2012, 10:51 AM
thatone thatone is offline
Garage is empty, add now
thatone is starting off with a positive reputation.
Need Part number info
I have a set of spindles and getting several different answers. I have not found the numbers on the spindles but have them off the backing plates D4TA-Lt 2k005 and D4TA- not stamped very well, possible P or F and 7 maybe? -2k004
Any help would be great, thanks.
  #2 (permalink)
Old 04-21-2012, 07:01 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Welcome to FTE
These are not backing plates, these are front disc brake dust shields.
Look closely at the suffixes of the marked ID numbers on your dust shields, compare with the Ford truck parts catalog suffixes, as there are two different types.
Marked: D4TA-2K004-EA or HA = Ford part number: D3TZ-2K004-B (replaced D4TZ-2K004-A) .. Right Dust Shield.
Marked: D4TA-2K005-EA or HA = D3TZ-2K005-B (replaced D4TZ-2K005-A) .. Left Dust Shield.
Applications: 1973 F100/250 2WD; 1974 F100/250 2WD before serial number U60,001 / ALL with single piston calipers.
Marked: D4TA-2K004-EB or HB = D4TZ-2K004-B .. Right Dust Shield.
Marked: D4TA-2K005 EB or HB = D4TZ-2K005-B .. Left Dust Shield.
Applications: 1974 F100/250 2WD from serial number U60,001; 1975/79 F100/150/250 2WD / ALL with single piston calipers.
The spindles have cast ID numbers on them, will be the same or similar to this: D3TA-3107-CD or DD right / D3TA-3108-CD or DD left.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #3 (permalink)
Old 06-12-2012, 10:36 AM
I know its been a bit but wanted to say thank you. Your knowledge is definitely invaluable and have used other post you have replied to in order to find the correct parts I needed. Thank you very much for you help.
Tags
dust, f250, ford, front, lookup, number, part, shield, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
