How to: 3G install for 83-92 IDIs - Page 2 - Ford Truck Enthusiasts Forums
Old 02-11-2014, 01:31 AM
BikeMaker's Avatar
BikeMaker BikeMaker is offline
BikeMaker is starting off with a positive reputation.
I stole the wiring from a OBS F-150 that came equipped with a 3G. Makes it pretty much plug and play except for splicing that one green wire off of the original voltage regulator.
Old 02-19-2014, 07:17 PM
huggyb1972's Avatar
huggyb1972 huggyb1972 is offline
huggyb1972 has a good reputation on FTE.huggyb1972 has a good reputation on FTE.
One thing I have noticed on mine though, the volt meter on my truck does not reflect the actual voltage being put out by the alternator. When I kicked on the heater, lights, and wipers the gauge goes down lower than 14 but the VOM I had connected at the battery showed full 14.79VDC coming in.
Old 03-24-2014, 07:28 PM
optikal illushun's Avatar
optikal illushun optikal illushun is offline
optikal illushun is gaining momentum as a positive member of FTE.
Kickin this back up to the top since a good majority of folks are begining to thaw out and will be once again roaming the junkyard
Old 03-25-2014, 08:48 AM
Gettysburg150's Avatar
Gettysburg150 Gettysburg150 is offline
Gettysburg150 is gaining momentum as a positive member of FTE.Gettysburg150 is gaining momentum as a positive member of FTE.
Could we get a how to section? Or maybe add this to the FAQ, great info
Old 08-16-2014, 03:45 PM
monte97z's Avatar
monte97z monte97z is offline
monte97z is starting off with a positive reputation.
Just want to say thank you. Your write up made this a easy conversion. Wish I would have done it years ago. Power is no longer an issue.
Old 08-17-2014, 12:09 PM
83capril's Avatar
83capril 83capril is offline
83capril is starting off with a positive reputation.
Great write up. Just got to find time and get this done.
Old 03-20-2015, 08:55 PM
Sarco3 Sarco3 is offline
Sarco3 is starting off with a positive reputation.
Thanks for all the information. I tried to complete this swap today and came across a few issues, perhaps someone who has finished this successfully can give me a few tips.
I pulled a 3g from a Taurus in the scrap yard and it tested good (my 1g had tested bad and had been putting out 11.6v/not charging the batteries enough to start). First problem I ran into was reclocking the 3g-- it moved maybe 20 degrees, then got stuck and I ended up having to tap it back to where I started with a wood block+hammer. Any tips on freeing it up?
I ended up connecting everything then bolting it in, not a long-term solution but I wanted to know if it would work.
Start up the truck and check the voltage, 11.6v on both my multimeter and the dash gauge just like the old, bench tested bad 1g. Very confused. I did re-use the alternator-starter solenoid cable and the old wire from that cable to the voltage regulator. I'm thinking that swapping to new cables and a fuse will fix it, is there anything else I should check? Waiting on a 175amp fuse+holder to come in the mail, sadly no one local had the holder. Thanks in advance for any help and to OP for the excellent write up.
Old 03-20-2015, 09:13 PM
Realslowww Realslowww is offline
Realslowww is starting off with a positive reputation.
So 93 n 94 F series 7.3 already have it ?
Old 03-20-2015, 10:39 PM
wtroger wtroger is offline
wtroger is gaining momentum as a positive member of FTE.wtroger is gaining momentum as a positive member of FTE.
Sarco3. Breakout a test light and or a vom Y/W wire should have B+ voltage all the time. G/R will have voltage with the key on but not much 2-3 volts. The W/B I haven't measured. Large stud should have Battery voltage all the time. When running voltage should be above 14 volts. See where you are not seeing voltage.
Old 03-21-2015, 12:43 AM
The_Josh_Bear's Avatar
The_Josh_Bear The_Josh_Bear is offline
The_Josh_Bear is starting off with a positive reputation.
Quote:
I may be reading this wrong--
Are you using the stock regulator still or just the wire itself?
Old 03-21-2015, 11:00 AM
Just the wire from the alternator stud to the starter solenoid. Not the stock regulator, wish all this was something that easy/stupid!
@wtroger: Will check all those this weekend. I measured the voltage at the batteries (11.6v) and at the starter solenoid where the cable comes in from the alt (11.6v). The weird part is that the batteries read higher, around 12.4, with the truck off...
What exactly do you mean by B+ voltage?
Old 03-21-2015, 06:40 PM
B+ is battery voltage. You need the green/ red wire that went to the original voltage regulator extended to the new alternator. The yellow/white wire can be hooked to the big stud on the alternator. the white/black is just a loop from the S connector on the ivoltage regulator to the single spade connector on the alternator.
  #28
Old 03-25-2015, 04:54 PM
Chevy_Eater's Avatar
Chevy_Eater Chevy_Eater is offline
Chevy_Eater has a very good reputation on FTE.Chevy_Eater has a very good reputation on FTE.Chevy_Eater has a very good reputation on FTE.Chevy_Eater has a very good reputation on FTE.
Quote:
Yeah, and 92.5
  #29
Old 04-13-2015, 12:32 PM
FordTruckfan89's Avatar
FordTruckfan89 FordTruckfan89 is offline
FordTruckfan89 is gaining momentum as a positive member of FTE.
Just sharing my experience, I just put one in my 89, picked up a 130 amp 8.25 spacing 3G from a 95 windstar. Did not have to grind or file anything, took the old pulley and shim off the 1G, took the old pulley off the 3G, put the shim on, then the pulley and torqued it down good, plenty of shaft sticking out of the nut, no need for loctite. used an extension, and had to re pin 1 wire in 1 plug for it to be plug and play, used a harness from a 95 7.3 truck with fusible links on the charge cable. Re-used the metric upper bolt, reused the belts, they fit fine. I did not have to cut a single wire, I did have to re-clock it though.
  #30
Old 04-28-2015, 03:28 PM
genscripter's Avatar
genscripter genscripter is offline
genscripter is starting off with a positive reputation.
Removed due to inaccuracies.
7.3 fuel system upgrade optikal illushun Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 30 10-20-2016 11:41 PM
Return Caps Rev. 1.0 mechelement Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 116 06-01-2016 10:12 PM
9" skyjacker lift question bmxbandit 1973 - 1979 F-100 & Larger F-Series Trucks 9 07-11-2014 11:19 PM
Post ur IDI! optikal illushun Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 37 04-06-2009 06:02 PM
Exhaust Repair - The Redneck Way G2IC_Wraith Ranger & B-Series 23 04-01-2007 04:49 PM
Tags
1992, 1997, 2008, 73, belt, duty, engine, f350, fender, ford, ranger, regulator, scion, super, voltage, xb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
