Installed my John Woods Valve Body WOW! - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 04-20-2012, 12:21 AM
Chipworkz Chipworkz is online now
Chipworkz is gaining momentum as a positive member of FTE.
As the title says, one of the many things I just did was install the John Woods valve body in my e99 truck. I also used the Mobil 1 synthetic fluid, added my radiator with OTW cooler and installed the 6.0 cooler. These other things I don't contribute to the shifting performance but were changed at the same time.
I got everything put back together and took it for a test drive. MAN what a difference. From the first shift I could feel a difference. The shifts are very fast but not harsh at all. Before if would take a couple of seconds to shift between gears but now it is instant! Whether I am giving it light throttle or WOT, it shifts the same with no harshness.
I had read where a few people said they didn't notice any difference and others said it really worked. Well for me, this is now how the truck should have been from the factory. It just works and work right!
If your transmission is stock and slow to shift between gears, this is WELL worth every penny.
Oh and I got it from Riffraff.
Old 04-20-2012, 01:00 AM
cutlass's Avatar
cutlass cutlass is offline
cutlass has a good reputation on FTE.cutlass has a good reputation on FTE.cutlass has a good reputation on FTE.
Great news! I'm looking forward to putting on my John Wood valve body when I get my truck up and running again. I can't wait to experience my transmission shift how you described.
Drake
Old 04-20-2012, 09:22 AM
miller_feed's Avatar
miller_feed miller_feed is offline
Hook it, I'll pull it.
miller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputation
Congrats.
If you think your trans shifts good now, get his built trans, then you will be excited.
Old 04-20-2012, 10:43 AM
JonathanN's Avatar
JonathanN JonathanN is offline
JonathanN has a great reputation on FTE.JonathanN has a great reputation on FTE.JonathanN has a great reputation on FTE.JonathanN has a great reputation on FTE.JonathanN has a great reputation on FTE.
I love mine... that coupled with Jody's tunes (he and John Wood work together) burnt especially for the valve body makes for an unreal combo.
4R100 Swap Technical Questions Derek86 Clutch, Transmission, Differential, Axle & Transfer Case 4 07-28-2016 08:59 AM
1994 F350 7.5 E4OD 2nd to 3rd gear problems. UrMedic 1987 - 1996 F150 & Larger F-Series Trucks 2 01-21-2016 08:12 AM
E4OD harsh late shifting... Nitro Blazer Clutch, Transmission, Differential, Axle & Transfer Case 4 08-01-2013 12:25 PM
harsh 1-2 shift E4OD Midnite1987 1987 - 1996 F150 & Larger F-Series Trucks 5 07-02-2012 08:46 PM
E4OD Cant Find the Shift Problem forensicpsyguy Clutch, Transmission, Differential, Axle & Transfer Case 1 02-14-2010 07:55 AM
Tags
64l, body, bodys, difference, duty, john, notice, powered, reviews, shifting, stock, super, transmission, valve, vbulletin, woods
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
