Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 04-19-2012, 03:24 PM
phoneman91's Avatar
phoneman91 phoneman91 is offline
Garage is empty, add now
phoneman91 is gaining momentum as a positive member of FTE.phoneman91 is gaining momentum as a positive member of FTE.
Pictures of 60 F100 4x4 inside cab corner reinforcements?
Any one have any close up pictures of the factory inside cab corner reinforcements on a 1960 4x4?
I am thinking of buying a 60 F100 4x4 and use to have some pictures of these reinforcements-but have misplaced them.
I want to verify that the truck is a real factory 4x4. It is my understanding that these reinforcements and the GVWR are the only way to tell a factory 60 F100 4x4.5000 GVWR are base/non DSO 4x2s and 5600 GVWR are 4x4s.
Is there other things to look for in a factory 60 F100 4x4? Sure are a lot of 110 inch wheel base "factory 4x4"s out there-and I know better than that . And I think that Mr ND has stated that all factory 4x4 have horn buttons and not horn rings.Even the 4x4 Custom Cabs.
__________________
92 F150 XLT 4x4, SWB, 5.0 V8, 5sp ,118k on M1/Amsoil synthetic oil. Power everything. Trailering/Handling option(stabilizer bars front /rear and quad shocks).Factory skid plates,manual hubs, manual Tcase, Super Cooling. 4.09/4.10LS axles. 31'' BFG KO tires. 20.3 MPG @ 60 MPH.4350 lbs with full tank of gas!! 2150RPM@60MPH All options but 4!
  #2 (permalink)
Old 04-19-2012, 07:27 PM
GB SISSON's Avatar
GB SISSON GB SISSON is offline
GB SISSON is gaining momentum as a positive member of FTE.GB SISSON is gaining momentum as a positive member of FTE.
Dang it phoneman, if I had a good pic of those reinforcements I would counterfeit them for my truck. when/if I convert it to 4wd..... and I sort of got carried away reading your sig about your '92. I'm partial to that year. I love my '92 also.......
__________________
'92 F350 4x4 dual wheel service truck. 7.3 with headers and glass packs. 5 sp man tran. 255 85 16 Toyos. 110,000 miles. '59 F350 9' flareside new project, cummins 6at turbo diesel, sm 465 4 spd. 255 85 16s again, 37 ford 1 1/2 ton stake with 53 flathead V8. 65 toyota landcruiser fj 45 longbed pickup. 54 GMC 3/4 ton flatbed w/ cummins 6at, '68 BSA 441 Victor Special, bone stock, Antique tractors and one lung flywheel engines .....
  #3 (permalink)
Old 04-19-2012, 10:44 PM
willowbilly3 willowbilly3 is offline
willowbilly3 is gaining momentum as a positive member of FTE.
According to my decoding information The VIN will start F10 For F-100 and F11 For F-100 4x4.
  #4 (permalink)
Old 04-20-2012, 09:31 AM
thundersnow70's Avatar
thundersnow70 thundersnow70 is offline
1960 Ford F-250
My Garage
thundersnow70 is starting off with a positive reputation.
im not sure if this is what your talking about but i will post a pic of my f250 cab brace. i would assume they are the same as on a f100. they seem to be welded in after the fact becauce the welds dont look to be as good as the rest of the cab fit and finish.
Click the image to open in full size.
GB, i could trace my brace on cardboard. write the measurements on it, then post a pic of it.
__________________
52 F2 & F3 Merryman Herringbone
60 F250 4x4
63 F250 4x4 Flareside
Mark
I might be in a cage at the zoo, but I'm still king of the jungle!
  #5 (permalink)
Old 04-20-2012, 07:45 PM
spurredon's Avatar
spurredon spurredon is online now
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
Just think about how much more dirt you could collect with a pair of those babys on the truck!
They must stiffen things up a bit!
  #6 (permalink)
Old 04-20-2012, 10:38 PM
GB SISSON's Avatar
I've got a putty knife and I'm not afraid to use it!!! Ok, maybe after I finish listening to Glen Campbell's greatist hits that Ravin surprised me with. OMG so awesome......
__________________
  #7 (permalink)
Old 04-20-2012, 10:40 PM
GB SISSON's Avatar
Perfect Thundersnow... My bird **** welds will match the factory aftermarket stuff to a T...........
__________________
  #8 (permalink)
Old 04-25-2012, 10:08 PM
1960 Ford F-250
My Garage
spur, i dont worry about them catching crud as it seems to fall out the cab corners. and GB, i will get it posted soon. been busy with the carb and getting the door squared away.
__________________
60 F250 4x4
Mark
Tags
100, 150, 1960, 1961, 4x4, 60, cab, corner, corners, f100, ford, front, image, pictures, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
