94 bronco starter probs>>
94 bronco, wont start...just goes clank when you try to turn it over. then wont do anything no lights no nothing no clank even. if you disconnect battery and reconnect it will show battery juice and lights/radio work but goes clank again. after a few times of this it turned over. did it with two different batteries too so its not the battery. Im thinking starter..any thoughts??? just want to be sure before i spend 120$ on starter. thanks
I'm wondering if you've got a bad cable or bad connection. With a good battery charged up, even if the starter motor is stalled and draws real high current, if you turn the key back to RUN, the starter relay on the fender will drop out, opening the circuit to the starter. So lights should go back on if they dimmed out when cranking.
DiscardedFrog66
09-25-2019 09:28 AM
Treay Turner
22
10-06-2017 11:00 PM
greenf150
01-20-2005 11:06 PM
