1988 f350 7.5L wont fire! - Ford Truck Enthusiasts Forums
Old 04-19-2012, 11:35 AM
hhtackle76 hhtackle76 is offline
hhtackle76 is starting off with a positive reputation.
Exclamation 1988 f350 7.5L wont fire!
so i have a 1988 f350 crew cab 2wd drw with the efi 460 in it and currently im trying to get it running. just the other day it was fine and yesterday i went out to go somewhere and it just cranked and didnt start. i can hear the fuel pump go on when i turn the key and i just changed mt filters.... any ideas?
Old 04-19-2012, 11:39 AM
Nealcrenshaw's Avatar
Nealcrenshaw Nealcrenshaw is offline
Nealcrenshaw is starting off with a positive reputation.
Check for a spark at the plugs.
Old 04-19-2012, 11:42 AM
i checked that and fuel pressure is normal
1988 f350 brush guard 1988fordf350 1987 - 1996 F150 & Larger F-Series Trucks 0 02-15-2015 11:04 AM
1988 F250 460 - compatible models/trans Finger__Rachet 1987 - 1996 F150 & Larger F-Series Trucks 6 04-28-2014 10:34 PM
injector issue haaaammmmmm Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 04-11-2013 11:58 AM
1988 F-150 reliability? neumayr83 1987 - 1996 F150 & Larger F-Series Trucks 7 08-08-2011 06:30 PM
need info 1988 F150 dixie rose 1987 - 1996 F150 & Larger F-Series Trucks 2 08-27-2003 03:37 PM
Tags
1988, 1994, 350, 75, 75l, 88, diesel, f350, fire, ford, motor, specifications, start, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
