P0401 EGR flow insufficient? - Page 5 - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
  #61
Old 03-18-2009, 02:39 PM
lsrx101 lsrx101 is offline
lsrx101 has a very good reputation on FTE.lsrx101 has a very good reputation on FTE.lsrx101 has a very good reputation on FTE.
Quote:
Originally Posted by bluedevil3758 View Post
... i got a p0401 code replaced it with one from autozone that was plastic...
That's the key phrase. Engine management/electrical parts from AutoZone are usually Wells brand, sometimes reboxed as Duralast. They have a very high failure rate. I won't touch them.
  #62
Old 05-09-2009, 11:57 AM
Leefpile Leefpile is offline
Leefpile is starting off with a positive reputation.
Ok, I'm new to this site. Just picked up a '02 Ranger 4x4 4.0 sohc, XLT package, 65xxx miles less than five months ago. About three months ago the CEL came on with P0400. I was digging around and was told it was the DPFE sensor. I replaced it and the light went off for about two months. It's back. P0401, insufficient flow detected... I have a multimeter, a handheld vacuum pump/guage and enough tools to do these repairs but I cannot figure this one out. Please help.
  #63
Old 05-19-2009, 04:58 PM
reynolds4864 reynolds4864 is offline
reynolds4864 is starting off with a positive reputation.
After a long search, this is the best site I've found that addresses the P0401 code issue. All the posts sound like my problem. However I have a 2002 Mercury Sable 3.0L DOHC (which is the Tuarus) and am having trouble finding the DPFE sensor. Any advise where it is on this engine?
  #64
Old 05-19-2009, 08:42 PM
ALAS! I fixed it, after about a month of randomly checking voltages, pressures, and other miscellaneous tests I said "F**K IT, I'll just try another DPFE sensor." Low and behold the light hasn't come back on yet!!! It's been a few days now, it seems to have fixed the hesitation for the most part, but it is still a little noticeable...
The real test will be my trip to Chicago this week. I'll keep you posted on the results.
*** Keep in mind that AutoZone has cheap parts, but I went to NAPA soon after. The DPFE sensor I grabbed from AutoZone failed, REAL QUICK... As of now I would say maybe check out NAPA. It's about $51.00 after tax. ***
  #65
Old 05-20-2009, 09:27 AM
pawpaw pawpaw is offline
pawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to behold
Quote:
Welcome to FTE.
I'm not exactly sure where the DPFE is located on this engine, but I'll bet the guys on the Taurus Car Club (TCCA) Maintenance, or Engine/Drivetrain forums will know, if you haven't already found them in your search.
Taurus Car Club of America -> Maintenance and Repair
You might also try AutoZones website & enter your vehicles particulars..
  #66
Old 06-08-2009, 07:10 AM
98expeditionXLT 98expeditionXLT is offline
98expeditionXLT is starting off with a positive reputation.
I have been fighting this P0401 problem on my 2000 Taurus and searched all over the internet. The last place I looked for info was this forum. It should have been the first place to look. Thanks for all the great input.
  #67
Old 09-19-2009, 05:22 AM
killit's Avatar
killit killit is offline
killit is starting off with a positive reputation.
I had the same code. Checked all tubes and vacuum lines, hoses, etc and cleaned them all with compressed air...
Removed the EGR valve and cleaned the port with throttle body cleaner and a toothbrush, it did not appear to be clogged.
I used a voltmeter on the DPFE sensor expecting it to be bad, but it read 4.8 volts, manual stating 4-6volts was good.
I thought maybe mine was going to be something else...
Before i put the EGR valve back on i was trying to check to see if it was stuck a little or working properly...
my brother took the air hose and shot it into the valve! DO NOT DO THIS!!!! POP! the air busted the diaphragm that works the valve up and down.
SO, i hoped it was the problem to begin with and spent $50 replacing it. Still got the code.
Another $50 for the DPFE sensor.
NO MORE CODE!!!!
It was probably that freaking sensor the whole time. I should have listened to this board and my gut and just replaced it first. Oh well.
And fwiw, i used autozone part - $53 versus $77 at Oreilly's, and has a 2year warranty. We'll see how long it lasts i guess.
  #68
Old 04-04-2010, 07:52 AM
slick351 slick351 is offline
slick351 is starting off with a positive reputation.
2000 Expedition 4.6
HELP!!!!!!!!!!!!!!!!!!!!!!!!
I have also been fighting this code problem:
Replaced:
EGR Valve, DPFE sensor, EGR Tube to Exhaust Manifold
Recently noticed that I had 2 broken studs at the exhaust manifold...Replaced exhaust manifold all new gasket, studs and double male connector for EGR tube to go in to the exhaust manifold
Reset and drove for about 30-45mins before the S.O.B light came on again.
Before I take it to the Mech. what else can I look for?
Thanks in advance
  #69
Old 04-04-2010, 08:09 AM
Maybe the vacuum switching valve's diaphragm is leaking, or leaking vacuum lines between it & the EGR valve.
The computer sends the VSV electrical signals to have it control the EGR valve by sending it vacuum pulses to open & close. So if any of the EGR systems vacuum plumbing is leaking, the system is weak, or doesn't work at all.
If the leak is bad enough you may have driveability problems, engine ping, or maybe lean codes too.
Look in the Tech Info thread for links on how to properly test & diagnose the EGR system, so you don't waste money throwing parts at the problem.
Let us now what you find.
  #70
Old 04-04-2010, 04:51 PM
Thanks.
As of right now she runs great. I will get on tracing the lines ASAP.
I will let you guys know what I find
  #71
Old 04-13-2010, 01:41 PM
For the past couple of months I've been fighting with this code just to get my emmissions completed for Maryland Inspection. We have to do it every 2 years.
Well I found the problem.....I finally decided to go to the junkyard and tinker with some junk Expo's with the top part of the motor still on... I removed the Throttle body and ERG port on 3 of them. Not sure what its called (bolts to the back of the Throttle body turns down and bolts to the intake..EGR valve bolts to the side of it) On all 3 of the Expo's I found that there are to smaller ports about the size of a Bic pen that turn down towards the intake. Both of the ports completely clogged with carbon turd build up. I had to forcefully push a screw driver in to get unclogged.
I came home and found the same on mine. Cleaned it out with Throttle body cleaner and a small pipe brush. Reset code and drove for about 200 miles. Went to get my vehicle emmissions done and YEA!!!!!!!!!!!!!!!!!!......Passed
Very Simple:
You can take this off while leaving the throttle body still on.. Only 4 bolts (kind of a pain to get to but all you need is #8 & 10mm socket (#10 is for EGR Valve) with a long and short extension, swivel screw driver and some type of pad to lay on if you need to.. I did mine in about 45mins
  #72
Old 08-27-2014, 09:24 AM
E_Net_Rider E_Net_Rider is offline
E_Net_Rider is starting off with a positive reputation.
Quote:
I agree about that Wells junk. Last the warranty if you are lucky. If not, you still end up doing the job twice. Better to pay twice as much, do the job once.
99 E150 4.2 V6 EGR code TXE150 1968-2013 Full Size Vans 2 01-03-2015 07:10 PM
F150 EGR Flow Insufficient bruening675 1997 - 2003 F150 2 06-06-2010 08:40 AM
Runs rough when especially when accelerate fjerstadt Explorer, Sport Trac, Mountaineer & Aviator 6 06-03-2010 09:12 PM
2001 4.6 Supercrew P0401 code RGrimes 1997 - 2003 F150 3 02-07-2006 01:36 PM
ODB Error Code P0401 / EGR Flow Insufficient Detected jtarkington Expedition & Navigator 1 12-31-2003 10:05 AM
Tags
2000, 2001, battery, code, codes, disconnect, egr, f150, flow, ford, insufficient, p0401, po401, ranger, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
