7.3 thermostat - Ford Truck Enthusiasts Forums
7.3 thermostat
Old 04-18-2012, 11:39 PM
bnelson2444 bnelson2444 is offline
bnelson2444 is starting off with a positive reputation.
7.3 thermostat
1995 what is the stock temp for thermostat? Or does anybody know a temp for awesome mph?
Old 04-18-2012, 11:41 PM
Quote:
That's for 1995 7.3 manual trans
Old 04-19-2012, 07:50 AM
tjc transport's Avatar
tjc transport tjc transport is online now
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
not sure, but i believe it should be 195 degrees.
only buy the thermostat from ford or international. parts store t-stats do not work in our engines.
Old 04-19-2012, 08:27 AM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
In 1995 I believe the stock thermostat was rated at 203*. I believe the 195* stat made its debut in 1996.
The 203* is a great choice for these engines. The change was made to the 195* for emissions reasons, but I have run both and IMO, the 203* is the way to go. Some will disagree with me, but that's my $.02.
Old 04-19-2012, 09:00 AM
Awitte58's Avatar
Awitte58 Awitte58 is offline
Awitte58 has a good reputation on FTE.Awitte58 has a good reputation on FTE.Awitte58 has a good reputation on FTE.
Question about the tstat...
What does it affect? Whats the difference.
I have read how some people said with different tstats they had different heat/A/C in the truck... but other than that
Old 04-19-2012, 09:04 AM
Talyn's Avatar
Talyn Talyn is offline
Talyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud of
No?
Mines working good.
Old 04-19-2012, 09:12 AM
redman84's Avatar
redman84 redman84 is offline
redman84 has a good reputation on FTE.redman84 has a good reputation on FTE.
Some will disagree w you nate but theres a huge 203* population that swear by them. I'm considering it myself by my mileage is currently so good that I'm scared to change anything.
Old 04-19-2012, 09:17 AM
Really the Tstat just controls the operating temperature of the engine. The Thermostat shuts down the flow of coolant through the engine until the coolant reaches the thermostat's rated temperature. It doesn't just "click" open 100% so it is an approximation, and the rated temperature is typically the point at which it is fully open. The heat works better because the engine is running hotter and the coolant flowing through the heater coil is hotter. It shouldn't affect the A/C at all though.
The big thing is that a diesel's combustion is by the heat and pressure created inside the cylinder. The hotter the engine is, the easier it is to make the fuel burn (to a point). Additionally the PCM adjusts the injection timing advance based upon EOT (engine oil temperature). Supposedly it starts advancing the timing around 185* EOT, and goes up from there. So really the engine isn't starting to run to its full potential until the PCM sees it is at optimal temperature. Besides, International installed 203* Tstats in all the DT444E's that they produced for medium duty use, so the engine was originally designed to run best at that temperature.
Old 04-19-2012, 09:20 AM
Quote:
I know some will disagree with me but I have run the 195 and the 203 (from dieselsite) in by '96 motor, and I am assuming the '95 motor I am running now has the 203* (it seems to run about the same on the gauge as my old 203* in the '96). I realy like it. It seems to warm up quicker and the heat gets real good and hot when it is cold out side. The truck definitely runs a lot better once it is warm and the faster I can get it warm on my short commute to work, the better.
Old 04-19-2012, 09:23 AM
Awitte58's Avatar
Thanks nate! Much appreciated...
I always knew it was a simple mod some people list or talk about doing, but I never really cared enough to do it since my heater is fine and my avg mpgs are around 16.
And judging by ur info I should have the 195*
Any way to check?
Old 04-19-2012, 09:29 AM
Any way to check?
That is correct. The only way I know of would be to put an auxiliary temp gauge on it and see were it runs. On the stock gauge (which is an approximation really) mine (with the 203*) runs right about in the middle or upper end of the R in NORMAL on the gauge. Right around the R or M most of the time.
Old 04-19-2012, 09:30 AM
RÖENTGEEP's Avatar
RÖENTGEEP RÖENTGEEP is offline
FOREIGN GURU
RÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to behold
Arrow
Any way to check?
I think the only way is to uninstall it and maybe it has stamped the *. IDK.
Old 04-19-2012, 09:34 AM
Quote:
That's the only way to know for sure, but as tough as the stock housing is to get sealed back up, I wouldn't recommend it.
Old 04-19-2012, 09:46 AM
Awitte58's Avatar
Hmmm thanks! I like to know things even when I may not do anything with it.. lol
May need it in the future!
Once I do the t500, IC, and injectors itll need the 203*
who knows..
Old 04-19-2012, 10:00 AM
redman84's Avatar
Quote:
I'm about to do oil cooler an new coolant. I guess just hit it good with the emory cloth and a new gasket is best chance for success huh?
Correct thermostat 460 PapaBearYuma 1973 - 1979 F-100 & Larger F-Series Trucks 10 01-11-2017 10:21 PM
240 thermostat john jamieson Ford Inline Six, 200, 250, 4.9L / 300 2 12-01-2016 06:52 AM
Are my temps high? cory5517 6.0L Power Stroke Diesel 10 05-25-2016 10:20 PM
Hotter temp thermostat or colder temp ?? DanielT28 1994.5 - 1997 7.3L Power Stroke Diesel 13 12-13-2012 06:21 PM
89 2.9L thermostat question Icicle Ranger & B-Series 4 11-19-2004 05:14 AM
Tags
1995, 2003, 67, 73, 73l, 94, diesel, f250, ford, gasket, install, powerstroke, rating, temperature, termostat, thermostat
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
