Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 04-18-2012, 08:40 PM
Challe Challe is offline
Garage is empty, add now
Challe is starting off with a positive reputation.
Smile Dual tank problem 1990 F 250 7.3
I have a 1990 F 250 7.3 diesel . Any help appreciated!!!!!
The fuel sensor on the front tank has not been working for over year. Just recently this truck has stopped running on me two times. I had it towed back to my home both times .One time I was driving and the other time the truck would not start after being parked for 4 hours at a fishing ramp. At home I started the truck by adding fuel & turning on the ignition switch , then pumping the accelerator about 10 times ,(WITH OUT TRYING TO START ENGINE )Repeated this procedure 3 times. I sprayed a shot of wd 40 in the air intake before starting the engine. Odds things are happening! I ran about 100 miles on the rear tank & when I decided to top it off with fuel ,This tank was full up to the neck ??? I am not dreaming!!!!!!!!
Any one knows what is going on ?????????<><>
Challe
  #2 (permalink)
Old 04-18-2012, 09:01 PM
86f250XLT-4x4's Avatar
86f250XLT-4x4 86f250XLT-4x4 is offline
1986 Ford F-250
My Garage
86f250XLT-4x4 is starting off with a positive reputation.
Sounds like the selector valve is bad
  #3 (permalink)
Old 04-18-2012, 11:39 PM
farmert farmert is offline
farmert is gaining momentum as a positive member of FTE.
Have you checked the fuse for the gauge? It also is the fues for the fuel selector switch.The selector valve is a good posibility, as some times they will draw from one tank and return it to another.
__________________
Tom
1985 F250 Reg. cab 6.9,94 factory turbo, zf5 speed, 3.55 4X4, flatbed, dual 3.5in. stacks
1990 F350 SRW Crewcab 7.3 turbo 4.10 zf 5spd 4X4
1997 F350 SRW Reg cab powerstroke 4.10, zf5spd 4X4, 3inch downpipe, 6637 mod, intercooler
1996 F350 Crewcab dually 4.10, E4OD, 3" downpipe, 6637 filter
1996 F350 Dually reg cab 4X4 flatbed all stock at the moment
  #4 (permalink)
Old 04-19-2012, 03:04 AM
joshofalltrades joshofalltrades is offline
1987 Ford E-Series Van
joshofalltrades is gaining momentum as a positive member of FTE.
you definitely have a bad selector valve, and possibly something else going on too. replace the valve, then post back with whats happening if you still have a problem
  #5 (permalink)
Old 04-19-2012, 04:34 AM
hookedondiesel hookedondiesel is offline
hookedondiesel is gaining momentum as a positive member of FTE.
I agree, sounds like the return is being directed to the other tank.
  #6 (permalink)
Old 04-19-2012, 07:45 AM
tjc transport's Avatar
tjc transport tjc transport is offline
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
and pumping the throttle with the engine not running does nothing, there is no accelerator pump on diesels.
__________________
Tom
JOIN THE NEW JERSEY CHAPTER CLICK HERE
owner of almost too many fords.
  #7 (permalink)
Old 04-19-2012, 03:02 PM
lemonshindig lemonshindig is offline
lemonshindig is starting off with a positive reputation.
Quote:
But pumping it once does set the fast idle.
-Matt
  #8 (permalink)
Old 04-19-2012, 04:34 PM
38Chevy454's Avatar
38Chevy454 38Chevy454 is offline
38Chevy454 is starting off with a positive reputation.
Quote:
-Matt
When cold it is required to depress the throttle some to let the advance to be set. Of course no fast idle when warmed up.
Back to the orig question, it sure does seem that your selector valve is messed up. If the fuel was at the top of the neck, it also probably was leaking out and if you look there should be evidence of the fuel leaking on the area aaround and under the filler. When it would not start at the boat ramp, was it on an angle? Could be your return line cap O-rings are leaking air and the angle made it worse by draining fuel back more due to height difference.
__________________
1949 F-6 COE hot rod
1988 F-250 4x4 7.3 5-speed ATS
1937 Ford Utility Coupe (Ute) hot rod
Other old non-Ford trucks and cars
  #9 (permalink)
Old 04-19-2012, 10:21 PM
Thanks ALL you nice people.
I just sent a post but I was not logged in so I guess it did not go?
In the fuse box I can't find a listing of the fuse for the gauge ? i also checked the Manual listing of the link fuses.I plan to change the selector valve.Where is it located?
I changed two leaking fuel injectors today .My back yard mechanic friend says that I was getting air blockage , and this is the reason my truck stopped running ???I am going to get this tank problem behind me before I drive this truck !!...... .What do you all think ? Is my problem the tank or was it the leaking fuel injectors???
Challe
  #10 (permalink)
Old 04-20-2012, 12:53 AM
the leaking injectors were definately ONE problem, but having one tank overflowing proves that the selector valve is also a problem. it can be found inside the left frame rail a bit forward of the front tank. its a black plastic valve with 6 ports, of which two go to each tank, and two go forward to the engine. the two going each direction are (of course) supply and return, with different sizes for the two.
replacing it is pretty simple: disconnect fuel lines and wire harness, unbolt from frame, install opposite of removal. line position should be idiotproof, as IIRC the lines from one tank to to the top of the valve and have "L" fittings on their ends, while the other tank's lines mount to the rear of the valve and have straight fittings. you'll see/understand when you start taking it apart
  #11 (permalink)
Old 04-20-2012, 04:36 AM
1986 Ford F-250
My Garage
Ok a side note for everyone sorry a little off topic though if your fuel line that crossed from driver side of the truck to the passenger side for the fuel supply to the engine make sure it stays tight to the frame (mine is loose and it rubbed a hole in it) and of course the engine was starved of fuel while driving it died at the light on me and wouldn't start
  #12 (permalink)
Old 04-20-2012, 08:06 AM
I changed two leaking fuel injectors today .My back yard mechanic friend says that I was getting air blockage , and this is the reason my truck stopped running ???I am going to get this tank problem behind me before I drive this truck !!...... .What do you all think ? Is my problem the tank or was it the leaking fuel injectors??? I sure appreciate all the posts<><>
Challe
It is the middle, 10 amp fuse in the second to the bottom row. Number 15. It is next to the power window circit breaker. You should hear a faint zipping sound from the selector valve when you switch from one tank to another. If your hearing is like mine, (not so good) you will need a helper. As stated the selector valve is in the drivers side frame rail at the front of the front tank. You can also feel the valve change if you have someone change the switch while you are under the truck. The key needs to be in the run position to change the valve from one tank to the other.
__________________
Tom
  #13 (permalink)
Old 04-20-2012, 09:54 AM
Wink Challe
Back again
There were no fuse in the fuse box# 15 location?. (Must have dropped out) I installed a 10 amp fuse ,but still no read out on the front tank.Could this have been the problem with my selector valve. My hearing is not to good,but I will run the check that you suggested next week on the selector valve when I have some help.I think I will wait until i make this check before I change the valve.
I feel that we are getting close to solving this problem<><>
Thanks again for the info
Challe
  #14 (permalink)
Old 04-20-2012, 04:02 PM
If there was no fuse in the #15 position, the fuel selector valve would not switch tanks. Hopefull this will cure you problem. Did the rear gauge read correctly before you replaced the fuse?
__________________
Tom
  #15 (permalink)
Old 04-20-2012, 07:40 PM
If this is a new truck to you, there could be a reason the fuse was out, just a thought.
You'll know, if it keeps blowing.
Tags
73, 99, diesel, dual, duel, f250, f350, ford, fuel, fuse, idi, location, problem, selector, switch, tank, tanks, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
