Air bags... - Ford Truck Enthusiasts Forums
Air bags...
Old 04-18-2012, 06:14 PM
SavageNFS's Avatar
SavageNFS SavageNFS is offline
not a WHITE truck
SavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputation
Air bags...
So I couldn't wait until Friday to install the airbags and wireless compressor. Firestone bags and AirLift wireless compressor. It took me just under 4 hours from start to finish. I love them already! Thanks to Epic's awesome video which made this install so easy...thanks!
Old 04-18-2012, 06:48 PM
Sailor_Roy's Avatar
Sailor_Roy Sailor_Roy is offline
Montana Chapter LDR
Sailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputation
Great Savage!
Sounds like you are a wee bit Happy already
We'll need a road report... empty and loaded
Old 04-18-2012, 09:12 PM
SavageNFS's Avatar
not a WHITE truck
So far so good...I ran to soccer with 20 lbs in the bags and the truck rode nice. It'll be next week before I pick up the 5th wheel and give them a real test. Truck is ready though!
Old 04-18-2012, 11:38 PM
shadowSVT shadowSVT is offline
shadowSVT is starting off with a positive reputation.
your going to love the bags.
I've had them on all 3 of my SD's and they are worth every penny.
I usually run with 5# in them unloaded and 45-55 towing, depending on how much firewood I have in the bed of the truck.
Old 04-19-2012, 06:00 AM
AirLiftCompany AirLiftCompany is offline
SPONSOR
AirLiftCompany has a great reputation on FTE.AirLiftCompany has a great reputation on FTE.AirLiftCompany has a great reputation on FTE.AirLiftCompany has a great reputation on FTE.AirLiftCompany has a great reputation on FTE.
Thanks for choosing one of our products. If you ever have any questions or concerns I would be happy to help any way I can.
Old 04-19-2012, 08:07 AM
SavageNFS's Avatar
not a WHITE truck
Thank you...I love the compressor so far. It works very well!
Old 04-19-2012, 08:36 AM
Jimax Jimax is offline
Jimax is gaining momentum as a positive member of FTE.
Nice. Curious to see how they do with the 5th wheel hooked up.
Old 04-19-2012, 09:29 AM
SavageNFS's Avatar
not a WHITE truck
I dropped the Air down to 10 pounds and the truck rode a little better empty. I will try 5 pounds later today.
Old 04-19-2012, 09:54 AM
jdadamsjr's Avatar
jdadamsjr jdadamsjr is offline
jdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputation
If you don't have one, get a low pressure air gauge like 0-15 lbs so you can tell the difference between 0,5, and 10 easier
Ah, on edit - u have the compressor - Dooh ! never mind !
the gauge I use for the truck just didn't cut it when going that low pressure, even though it was digital !
Now that I've messed up enough with this - I have a process
Measure your height with the bags @ 5 psi,
load up the 5er and bring it back to that height....
I also have a trail air pin setup that needs air to to bring the shock up to the right level, so I got a battery operated Ryobi air pump I can pull around it all
Ryobi - Air Inflator / Air Pump / WorkLight (Brand New) Cordless Unit on eBay!
Old 04-19-2012, 10:14 AM
SavageNFS's Avatar
not a WHITE truck
jdadamsjr...I was actually planning on doing exactly that! I just took a small ride with the bags at 5psf. I think that is the sweet spot empty. We are going wheeling Saturday so I'll hook up the ATV trailer to the truck and bring it up to the height of the truck with the 5 psf in the bags. I'm guessing it will take 20-25psf as that is only around 6000 pounds and around 750 pounds of tongue weight.
I pick up the 5th wheel next week. I have a few things to finish up here over the weekend and then I will be ready for it. We basically made a driveway into the woods behind the house to make room to park it. From time to time, family will actually stay in the trailer when they come to visit.
The first time I hook up to the 5th wheel, I may need to adjust the height of the B&W in addition to getting the correct height on the truck. Ideally, I want the trailer level with the truck at the same height as with 5psf in the bags. The B&W has three height adjustments for the plate. I have mine set at the highest currently. I'm hoping for 6" between the bed rails and the trailer as when I back into my property, there is a rather steep hill that we back up. I'm going to need a set of eyes the first time to gauge how close the 5th wheel gets to the bed rails. I don't think it will touch, but I want some room. When I pick her up the first time, I'll at least be able to get the B&W plate height to where I think it needs to be and adjust as I get more familiar towing the trailer. Does this sound reasonable or do you all have some different opinions?
Last edited by SavageNFS; 04-19-2012 at 10:40 AM. Reason: apparently, I can't spell...
Old 04-19-2012, 10:36 AM
jdadamsjr's Avatar
you are on the right path as far as my Days of experience show
be slow and methodical with your new toy - I was for the first month - then got 'confident'
train your second set of eyes to tell you only what you need to hear... not a long description - just the commands !
first and foremost STOP "loud with hands up" is as far as I've gotten with the new wife!
the rest of it I get out to look
(Oh and warning about making family TOO comfortable..... they tend to stay !)
Old 04-19-2012, 10:39 AM
SavageNFS's Avatar
not a WHITE truck
Thanks! My spotter is actually my 14 year old daughter most times. She is actually really observant and good at communicating with Dad.
Old 04-19-2012, 12:46 PM
Sailor_Roy's Avatar
Montana Chapter LDR
You got it !! Have Fun
Family...... "Remember, Family - Fish - Friends all stink after 3 days"
Old 04-19-2012, 12:49 PM
SavageNFS's Avatar
not a WHITE truck
truer words have never been spoken...
Old 04-19-2012, 01:01 PM
FishingNut's Avatar
FishingNut FishingNut is offline
FishingNut has a great reputation on FTE.FishingNut has a great reputation on FTE.FishingNut has a great reputation on FTE.FishingNut has a great reputation on FTE.
Savage,
I did not notice a heat shield on the airbag on the right rear...was it hiding or not necessary?
This is prolly a 1 page thread at most SavageNFS 6.7L Power Stroke Diesel 61431 Today 04:28 PM
For Sale: 2011 Superduty Head lights, Tail lights, 3rd Brake light and Mirror lights SavageNFS All Other Items for Sale 1 01-15-2016 10:39 AM
DPF "ON" MiniMaxx install SavageNFS 6.7L Power Stroke Diesel 55 05-03-2013 07:59 PM
Excurision lengthened... SavageNFS Excursion - King of SUVs 5 07-18-2012 01:17 AM
Man down... SavageNFS 6.7L Power Stroke Diesel 139 07-16-2012 04:05 PM
Tags
2006, 2012, 2535, 25c94, air, bag, bags, bed, bigfoot, duty, f250, firestone, heavy, installing, kit, long
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
