2001 Ranger A4LD 1-2 delayed shift - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 04-18-2012, 05:53 PM
havoxx33 havoxx33 is offline
havoxx33 is starting off with a positive reputation.
Hey guys. Brother in law has the above truck with shifting problem. On a cold start, pulling out of the driveway, it will get to about 3-4000 rpm and will slam into gear. Sometimes its worse than others, but is consistant. Once it warms up, the problem goes away for the most part.
I've researched a little online and have found a few people mention the 1-2 shift accumulator (servo...?) and was wondering if any of you have ran into this or have replaced one on the A4LD. And if you have, which servo is the 1-2 shift? I think there are 6 of the little suckers in there. Anyway, all i've done so far is fluid and filter. Old fluid looked/smelled fine. Thanks for any help you can send my way!
BTW I can't get on too often so if I dont reply right away, bear with me. Thanks fellas
Old 04-19-2012, 09:08 AM
KhanTyranitar's Avatar
KhanTyranitar KhanTyranitar is offline
KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.
2001 Rangers's don't have an A4LD. The last year of the A4LD is 1994.
The obvious things, make sure it is filled tot he proper level, make sure its the right fluid, and it it has more than 30,000 miles, the old fluid is not fine.
Beyond that, take it to a professional and have it professionally diagnosed.
Old 04-19-2012, 06:25 PM
I appreciate the help man. I gave my vin number to the local Ford dealer and that's what they gave me. Sorry for the mis-info. Fluid is the right level and correct type. Can't afford the professional diagnosis, hence me asking questions on this forum. I'll do some more research. Thanks for the input
Old 04-20-2012, 01:03 AM
Most professional diagnosis is free. What you can't afford is for it to fail catastrophically, which if you keep driving it is the next logical result.
The problem might be simple, but without a diagnosis by someone who has the experience and equipment, your really just throwing darts blindfolded.
Old 04-28-2012, 09:37 AM
02FX45.4 02FX45.4 is offline
02FX45.4 is starting off with a positive reputation.
How many forward gears does that truck have? 4 or 5? It is either 4R44E, 4R55E, 5R44E or 5R55E of course the first number denotes the number of gears the trans has. Anyway they both have similar characteristics on the outside. The reason for the delayed shift can either be a worn out or broken servo which is on the passenger side of the trans blocked by a cat convertor and is the rear of the 2 there or you have a broken or worn out band in the transmission. Now with the servo the cap which is about 3 1/2 inches in diameter, take a magnet to see if it is steel or aluminum. If it is aluminum then that can be changed to steel which I recommend.
Old 04-29-2012, 09:42 AM
tomw tomw is offline
tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.
How about a sleepy VSS? If the vehicle speed sensor is having morning sickness, or didn't get its cup of coffee, it could be sending bogus info to the computer, which would then not push for up-shifts. A TPS that had glitches could do something similar. If it had a MAP, that could be telling the computer that the throttle is wide-open, so keep it in gear until it HAS to upshift. If it has a vacuum modulator, that could be sticking also, again, telling the smarts to stay in lower gear.
If the servo were not working, thinner fluid at operating temp would lead to it NOT working even worse, right?
The above is all generic, but it may be possible to test the action of the solenoids using gear at a dealer or transmission shop. I think the VSS and TPS information should be available from the OBD-II diagnostics.
tom
Old 05-07-2012, 02:48 PM
Quote:
You would think it would work that way but when they get hot they expand thus sealing a little better than when cold. And the depends on if the caps are steel or aluminum.
DIY electronic automatic/manual control of A4LD? Jesse Gordon Clutch, Transmission, Differential, Axle & Transfer Case 0 10-09-2016 02:58 PM
A4LD - 4R44E and 4R55E 96_4wdr Aerostar 6 12-13-2012 11:48 AM
Rear Servo Function- 4R55E Transmission easygoin4 Ranger & B-Series 10 04-05-2012 09:17 AM
A4LD Slippage in all gears, pump? diversenerd Bronco II 13 02-20-2010 08:44 PM
1-2 hard shift Mud-and-Guts 1987 - 1996 F150 & Larger F-Series Trucks 12 01-03-2010 07:15 PM
Tags
12, 4ald, a4ld, accumulator, delay, delayed, f150, ford, hard, ranger, rangermazda, shift, shifting, shirt, slow
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
