'98 F-150 standard cab left side door adjustment
I'm trying to get the drivers side door to close and feel I need to shim the hinges some. I'd like to be able to shim the top hinge on the body side. The bolts are hidden behind the edge of the fender. How do you access these bolts? Any body peope out there? Thank you. bl2009
Easy fix
I know the post is old, but I feel I should add my experience.
Backed into the garage with my door open one day, not paying attention and the door slammed into the side wall of the garage while the truck kept going.
Hinges got messed up pretty badly, the front edge of the door was rubbing on the rear edge of the quarter panel and there was no way I could daily drive the truck this way without avoiding further damage.
Ended up removing the entire quarter panel, which is MUCH more involved than you’d think. Just have patience and bag and label all the different bolts you’ll need to remove. Helps to remove the tire where you're working. After this quarter panel is off you'll be able to loosen and readjust the hinges. It’s a long aggravating process but if you fix it right the first time, you won’t regret it. I got it done in one night.
