Corporate 14 bolt swap - Page 2 - Ford Truck Enthusiasts Forums
Old 04-19-2012, 05:31 PM
hairyboxnoogle's Avatar
hairyboxnoogle hairyboxnoogle is offline
hairyboxnoogle is gaining momentum as a positive member of FTE.hairyboxnoogle is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by ChaseTruck754 View Post
I think you read that wrong. The 14b or d60 would match your current front end (or be slightly narrower is a d60 front), but the 10.5 sterling would be 3" wider.
Ok so the 14b and D60 / 70 are the same width as my king pin 60 front? and the 10.5 is 3" wider. Thats better, i was thinking i heard the 14b was 3" narrower than the dana axles.
Wider isnt a concern, but i dont want narrower, an inch or so is no biggie but i dont want it noticable, if anything the rear needs to be wider to make what im diong to the bed look better.
Old 04-19-2012, 05:32 PM
ChaseTruck754's Avatar
ChaseTruck754 ChaseTruck754 is offline
ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.
I'll wait for Fordworth to clarify on the sterling, but from what I remember the corp 14 is the same width (or just slightly narrower) than my front d60.
Old 04-19-2012, 05:35 PM
Quote:
Originally Posted by Fordworth View Post
Yes, a 10.5 from a 99 or newer is wider than a 10.25, D60 or 14 B.
Did they not use 10.5's before 99? I was thinking you could get a 10.5 pre metric lugs.
Old 04-19-2012, 05:37 PM
Thats a relief, i knew the old body chevies the IFS was quite a bit wider than the rear, so i wondered if the rear was narrow, i had always thought that the front was wider, and they kept the same width rear from the solid axle days.
i think i may have said this before, but i love your sig.. "have you flown a ford lately" always makes me smile
Old 04-19-2012, 05:38 PM
Just a hint: I'm not sure if van's ever went metric. I know the E-250's & 350's were still 8x6.5 til 2009 or 2010 at least.
Old 04-19-2012, 05:47 PM
Correct you are, but as far as i know theyre all D60's
Old 04-19-2012, 05:49 PM
I swear I've heard differently but I'm not sure it was correct now.
Old 04-19-2012, 05:53 PM
We may both be right/wrong. I have heard a 100 times about D60 from newer vans being 8 on 6.5, but ive not heard one peep about the 10.5 in them. A rear from a 2006 econoline is going to be more than i want to pay anyway probably, but wont hurt to look i guess.
Old 04-19-2012, 05:56 PM
while were more or less on the subject, what would you guys recomend for a "traction aid" in the rear. Something that will handle some abuse, perform well, get decent use out of (longevity), and not snap crack and bang, if you can tell im not a fan of auto lockers. Been thinking an auburn limited slip.
Old 04-19-2012, 06:18 PM
I plan on going detroit true trac.
Old 04-20-2012, 10:36 PM
is it a clutch type or gear type?
Old 04-21-2012, 01:30 AM
Fordworth's Avatar
Fordworth Fordworth is offline
Fordworth is starting off with a positive reputation.
From what I understand the vans used Dana 60s and 70s but no Sterlings and they did keep the 8 on 6.5 until they were discontinued.
As for the width thing, a D60 front is wider than a D60 rear, 14B, or 10.25. The 10.5, however, matches the D60 front but they are all metric.
  #28
Old 04-21-2012, 02:26 PM
Well humph... Chase said you had yours redrilled for 8 on 6.5? Where should start looking for a 10.5? 99+ one tons?
Starting to think about getting both SD axles and just throwing in..
  #29
Old 04-21-2012, 03:35 PM
nitro_rat's Avatar
nitro_rat nitro_rat is offline
nitro_rat is starting off with a positive reputation.
The 10.5's from the '80-'97's drop in to dents, just need U-bolts toatch axle tube diameter. Spring perches, shocks, etc. all line up. Put one in my LWB '74 years ago. Driveshaft is 3.5" shorter than the 9," I have the shaft yoke swapped to match the diff yoke when the driveshaft is shortened. That way there's no conversion joint.
For 14-bolt info, poke around at Offroad Design - Fullsize Chevy GM 4x4 Suspensions, Parts and Performance, they have all the available dimensions on their site. Steve is super helpful, although they've grown tremendously and I don't know if he still answers tech questions via e-mail personally any more.
  #30
Old 04-21-2012, 07:38 PM
Thanks for the handy info sir, i didnt know the 10.5 was around that long. To be honest there isnt much at all i knew about them in the first place. Dumb question, but so im not looking for something that doesnt exsist... the 10.5 was DRW and SRW correct? I assume just start looking in 80+ 350's?
Leaf Spring Install Help - 77 F250 Joel Cassell 1973 - 1979 F-100 & Larger F-Series Trucks 2 04-03-2016 08:12 PM
A different type of leaf spring question jimcar-9 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 10-31-2014 12:36 PM
MII Front end coil spring question Tyler S 1948 - 1956 F1, F100 & Larger F-Series Trucks 43 02-25-2014 03:05 PM
Steering box adjustment - have I gone too far? Junx69 Excursion - King of SUVs 7 02-01-2012 06:56 PM
Spring lox for a inch of lift up front for only $15! 93f250tn 1987 - 1996 F150 & Larger F-Series Trucks 14 01-10-2010 07:54 PM
Tags
1025, 105, 14, bearings, bolt, brake, difference, drw, ford, hardware, parking, setting, srw, sterling, wheel, widening
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
