2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
07 expedition 5.4L cylinder 6 misfire
Old 04-17-2012, 09:00 PM
mdec950's Avatar
mdec950
mdec950 is offline
so its running rough and has check engine light cylinder 6 misfire
changed all plugs autolite HT1
changed all coil on plugs
changed cylinder 6 fuel injector
Took off all fuel injectors hand cleaned them with intermittent battery and fuel injector cleaner and compressed air
they are all very clean now
changed cam sensor
changed crank sensor
changed fuel filter
ran premium gas
added seafoam 1 tank ago
cleaned maf sensor with cleaner and air dryed
I have no oil in water
no water in oil
i have cleared codes
swapped items back and forth
and still cylinder 6 misfire
any ideas from you folks that have been on here awhile ????
should i check compression on all cylinders next ?
What is the min max for cylinders usually ? any thing under 100 bad ?
Also works great under 45mph
but when i get up to 60mph the check engine light comes on and cyl 6 misfire and stays on after a couple of times
HELP
Old 04-18-2012, 11:00 AM
berry1234's Avatar
berry1234
berry1234 is offline
I would have checked compression before buying any parts.
Part 1 -Troubleshooting Misfire Codes Ford 4.6L, 5.4L
Old 05-01-2012, 08:28 PM
mdec950's Avatar
mdec950
mdec950 is offline
it was a bad plug from autolite
berry1234 - that was not too helpful
it was a autolite spark plug that was the issue
i changed it to a new autolite same issue
changed to motorcraft sp151 plug and it runs fine now
se to fit
oh compression was 115 and held on a leak down test for 45 minutes
i would have checked compression but the threads are a diff mm size on this one so i had to order a hose for it
Old 05-02-2012, 11:43 AM
berry1234's Avatar
berry1234
se to fit
I think it was. Replacing multiple parts hoping it fixes a problem is not a good idea. Start with the basics. Diagnosing, testing, etc. spending money.
Regardless, I am glad you found the issue. I have heard anything other than Moto spark plugs will cause problems.
Old 05-11-2012, 08:09 PM
mdec950's Avatar
mdec950
mdec950 is offline
oh its fixed
no "real thanks" to anyone on these forums
Old 05-14-2012, 12:22 PM
berry1234's Avatar
berry1234
Then maybe you should go elsewhere. I offered advice. You didn't like it. It was solid advice. Throwing parts at a problem is ridiculous by any mechanics definition. It's a waste of money.
Old 02-07-2015, 08:58 PM
deputy69's Avatar
deputy69
deputy69 is offline
2008 Ford Expidition King Ranch
I have a 2008 Ford Expidition King Ranch got a code for camshaft position sensor. So I changed both cam shaft sensor's still missing but no trouble codes. Any ideas what it would be
Dan Robertson
2004 - 2008 F150
04-08-2017 05:12 AM
daveya48187
1983 - 2012 Ranger & B-Series
07-19-2013 08:17 AM
ckford_pickup
01-25-2011 07:13 PM
901fan
Modular V10 (6.8l)
12-14-2010 05:23 PM
dathantarah
1997-2006 Expedition & Navigator
11-06-2007 09:37 AM
Quick Reply: 07 expedition 5.4L cylinder 6 misfire
