Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 04-17-2012, 09:00 PM
mdec950 mdec950 is offline
Garage is empty, add now
mdec950 is starting off with a positive reputation.
07 expedition 5.4L cylinder 6 misfire
so its running rough and has check engine light cylinder 6 misfire
changed all plugs autolite HT1
changed all coil on plugs
changed cylinder 6 fuel injector
Took off all fuel injectors hand cleaned them with intermittent battery and fuel injector cleaner and compressed air
they are all very clean now
changed cam sensor
changed crank sensor
changed fuel filter
ran premium gas
added seafoam 1 tank ago
cleaned maf sensor with cleaner and air dryed
I have no oil in water
no water in oil
i have cleared codes
swapped items back and forth
and still cylinder 6 misfire
any ideas from you folks that have been on here awhile ????
should i check compression on all cylinders next ?
What is the min max for cylinders usually ? any thing under 100 bad ?
Also works great under 45mph
but when i get up to 60mph the check engine light comes on and cyl 6 misfire and stays on after a couple of times
HELP
  #2 (permalink)
Old 04-18-2012, 11:00 AM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
I would have checked compression before buying any parts.
Part 1 -Troubleshooting Misfire Codes Ford 4.6L, 5.4L
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #3 (permalink)
Old 05-01-2012, 08:28 PM
it was a bad plug from autolite
berry1234 - that was not too helpful
it was a autolite spark plug that was the issue
i changed it to a new autolite same issue
changed to motorcraft sp151 plug and it runs fine now
se to fit
oh compression was 115 and held on a leak down test for 45 minutes
i would have checked compression but the threads are a diff mm size on this one so i had to order a hose for it
  #4 (permalink)
Old 05-02-2012, 11:43 AM
berry1234's Avatar
se to fit
I think it was. Replacing multiple parts hoping it fixes a problem is not a good idea. Start with the basics. Diagnosing, testing, etc. spending money.
Regardless, I am glad you found the issue. I have heard anything other than Moto spark plugs will cause problems.
__________________
  #5 (permalink)
Old 05-11-2012, 08:09 PM
oh its fixed
no "real thanks" to anyone on these forums
  #6 (permalink)
Old 05-14-2012, 12:22 PM
berry1234's Avatar
Then maybe you should go elsewhere. I offered advice. You didn't like it. It was solid advice. Throwing parts at a problem is ridiculous by any mechanics definition. It's a waste of money.
__________________
Tags
1999, 2005, 2007, 46, 54, compression, cyl, cylinder, expedition, expeditioncyclinder, ford, misfire, misfiring, number, numbers
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
